cheap heavy duty truck reliability
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jhracing, Mar 27, 2017.
  1. jhracing
    jhracing Bobtail Member
    4
    Hi guys,
    I'm looking for a really cheap (5-12K) used HDT to pull my personal race trailer (18K gross) a couple of times a year (2-5K miles per year usage). Most of the time the rig will probably sit and get wiped with a diaper. I've looked at hundreds of egr and pre-egr trucks (auctions, private parties, etc.) and have found myself really undecided as I've learned more about HDT's. As the engines approach the B50 marker I realize there is risk with any used truck but that said... if you were going to purchase a higher mileage cheap used truck (1M range) for private hauling- which ones would you choose and which ones would you stay away from in that mileage range? Less concerned with fuel economy, and more with having to dump money into it for repairs. Like to put in key, have it handle it's business like a Honda.
    I've looked at various options in this price range:
    2006ish Used KW T2000'w with the C15 motors in the 1M range (acert twin turbos are cheap)
    2005ish FL Columbia's with the Detroit 12.7 or N14 in the 1M range (heard good things about those engines)
    2004-2008 Volvo 670's/780's with the D12 or ISX in the 1M range (D12 with freshened bearings may be good)
    2000-2007 FLD 120's or International Eagle's?
    2012-2014 Used Prostars with Maxxforce 13's in the 250-800K range (no further memo needed- this would be assuming I could find one without a check engine light on)
    Any help would be appreciated.
  3. benjamin260_6
    benjamin260_6 Medium Load Member
    433
    484
    Aug 8, 2012
    Ontario, Canada
    Fresh bearings on an electronic engine doesn't mean anything. Any emissions engine (EGR, DPF, SCR) that's had work on any part of the emissions doesn't mean it's fixed and you're good to go. It means you're going to change that part again in the near future. The best thing you could do, in my opinion, is go with a 2003 or older but not so old that it's got a mechanical engine.
    Oxbow, Mattflat362 and HaulIt Thank this.
  4. Diesel Dave
    9,301
    29,908
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on any pre emissions engine. You should be exempt in states which enforce emissions because according to what your saying, you will be running under 5k a year, well at least in California.
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    If I was going to purchase anything that had a million on it, it would definitely have a CAT motor. Second choice would be the N14.
    Truck would be a Freightliner Classic or Columbia, just for the sheer volume of dealers and parts support.
    Stay away from automatic transmissions too.
    Oxbow and charlie1403 Thank this.
  6. charlie1403
    charlie1403 Bobtail Member
    42
    22
    Sep 29, 2013
    Australia
    I'm biased but go CAT first,second and third choice. 6NZ or MXS/ NXS acert. Find one with a known service history including oil tests if possible, roll in new bearings if not already done and away you go. A nice deep growl under the go pedal and reliable as hell.
    Oxbow Thanks this.
  7. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    CAT with the two turbo would be my choice. Next down is detroit, but those have been worked.
    Agreed on the mechanical engine. When they are running correct the music is beyond wonderful.
  8. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    go price some parts on a cat. they're expensive.
    you want cheap and reliable? i'd get something with a pre emission detroit 60 series. and the fuel mileage on those is the best as well. a freightliner FLD with a 60 series may not give cb bragging rights but it'll be cheap to buy and cheap+and EASY+ to fix.
  9. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    cheap and truck don't go together unless your lucky
    Oxbow, passingthru69 and charlie1403 Thank this.
  10. lilillill
    5,642
    13,472
    Nov 7, 2007
    Cat parts I've had to buy since I've owned this 2007 Columbia (three years)...
    Compressor coolant hose $43
    Fuel transfer pump $186
    Coolant diverter valve rebuild kit $108
    Precooler hoses $40
    Rocker studs (admittedly pricey) $500
    Injectors cleaned, tested, new o-rings $300
    Now some things that can go and are not cheap...
    Turbos $3k each
    Precooler $850
    Injectors $600
    Water pump $700
    Internal wire harness ? (Anyone?)
    VVA solenoids ??
    Keep the oil changed. Use Cat filters. Never fill the secondary filter with fuel and never let it get so plugged that it blows the element out.
    It will run a long, long time.
  11. Ristow
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    we ran detroits all thru the 90's up till you could get them only in freightliners,and we weren't gonna downgrade on the truck because of the motor. we ran KW and Petes. a lotta detroits.
    after that we went with cats. we ran a lotta cats. 6nz thru Acerts. they had their issues. but also they did fine by us,i aint baggin' on cats. but they are more expensive to own,and run.
    Cats are great motors,probably the biggest power makers too. but we probably went inside more cats that detroits. certainly not fewer.
    and there is the whole bragging rights thing about cats. some guys need that. some guys don't.
    i think for a single o/o its hard to beat the value ,ease,and economy of owning and running a 60 series.
    Oxbow Thanks this.
