cheapest way to add lubricity to ulsd
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shogun, Jun 14, 2009.
  1. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Just fyi, I read on another site about an independent lubricity study. It included a lot of popular additives and rated them for lubricity according to the US gov't standard scar wear test. One of the best and the cheapest additive was two cycle oil (ashless) like wal-mart supertech tcw-3. I've been using it in a 1999 detroit 500, and it definitely quiets injectors and does a little better on fuel. Overall, the engine runs better. Its recommended to add an ounce per gallon, and it runs just under 11 bucks a gallon. It has the same btu rating as diesel fuel also. The study can be found by doing a search on diesel additive lubricity study. Hope it helps someone. BTW, not recommended for newer engines.
    7mouths2feed Thanks this.
  3. 24valve puller
    24valve puller Medium Load Member
    399
    89
    Sep 8, 2007
    N.E. Oh
    I use a additive from a local guy, it costs around 2.5 cents per gallon of fuel treated bought in a 5 gallon bucket. his site is renewablelube.
    GRAYMATTERS and 7mouths2feed Thank this.
  4. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    I normally just use Lucas products but I know a feller that addes a 20oz bottle
    of oil to each tank everytime he fuels.
    Thats the bad thing about the USLD, the fuel is very dry.
  5. ctbird53
    ctbird53 Bobtail Member
    9
    Jun 14, 2009
    mt pleasant,tx
    Put a quart of cheapo trans fluid in each tank when you fuel
  6. shogun
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Ctbird, I have read various places not to put newer transmission fluid in the fuel because of the friction modifiers and additives, plus the ash content. It did work back in the old days, just not the newer stuff. Thanks for the tip 24valvepuller.
  7. shogun
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    Coonass, just fyi the lucas faired poorly among the products tested. I have used it also.
    Coonass Thanks this.
  8. Peanut Butter
    Peanut Butter Road Train Member
    1,343
    419
    Nov 24, 2007
    PO Dunk Idaho
    Putting trans fluid in your tanks makes the fuel have a red color which will almost get you fined at a scale when checked unless you can prove its trans fluid and not off road fuel, this happened to a friend of mine who puts that in during the winter for anti gel, he was checked but was able to convince the dot guys it was infact trans fluid in there for the winter.
  9. GRAYMATTERS
    GRAYMATTERS Light Load Member
    180
    92
    Apr 13, 2009
    Colorado
    How long have you used it?
    Have you used it during the winter?
    Any other info would be greatly appreciated.
  10. 24valve puller
    399
    89
    Sep 8, 2007
    N.E. Oh
    I've used it for two years now, they have a winter blend but I have never bought it. I used it the last two winters with no problems, I have it in a gallon jug in the side door on my bunk and have never seen any kind of gelling or thickening or have ever been shut down by it. I buy it in a 5 gallon jug and it lasts me 60-70k miles. I used to use lucas before this and knock on wood I have not had any mechanical injector failures since I started useing an addative, this stuff is about the same price as the lucas but treats 4 times the fuel per gallon of treatment
    GRAYMATTERS Thanks this.
  11. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    just blending in 2% soybean oil would solve the lubercation problems of ULSD uping it to a 20% blend and you would even gain some MPG
