check engine after truck wash
Discussion in 'Volvo Forum' started by Edgar2191, Sep 9, 2013.
  1. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    Truck is a 2009 volvo 670 cummins isx engine. I whent to the truck wash started driving check engine light came on and it says crankcase pressure electrical fault active.
    DoneYourWay Thanks this.
  3. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Bet your ecm got wet
  4. Edgar2191
    178
    33
    Apr 9, 2013
    What problems could this bring me? How can I help it dry
  5. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    Happens to my Cummins all the time, usually only crankcase pressure code, after couple miles down the road it clears itself
  6. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I'd guess since you just got it washed they got the crankcase breather filter wet. Look at the left front of the engine you'll see a plastic box. Check to see if the filter is wet. Either that or the plugin connector for the crankcase pressure sensor got wet.
  7. gerardo1961
    gerardo1961 Road Train Member
    1,737
    600
    Feb 21, 2010
    Miami
    For this when i wash my truck,everytime without enginewash,less troubles with electonic
  8. juanveldez
    juanveldez Light Load Member
    152
    44
    Apr 24, 2007
    Iron Mountian MI
    They sprayed the ecm when they washed it. Before I started driving I worked in a truck wash and have had trucks that wouldn't even turn over if we got the ecm wet.
