Check Engine code SA 16 DTC P 245364 Volvo D16
Discussion in 'Volvo Forum' started by ahluwalia123, Sep 4, 2017.
  1. ahluwalia123
    ahluwalia123 Bobtail Member
    4
    Hi guys does anyone know about code
    SA 16 DTC P 245364? in Volvo D16, is it a
    Big issue do I have to go to repair shop or just let it be like that
    Thanks
  3. chauhan12
    chauhan12 Bobtail Member
    33
    6
    Jul 26, 2017
    Might be related to DPF, could be the sensor or the filter.
    ahluwalia123 Thanks this.
  4. ahluwalia123
    4
    Is it a big problem to check it immediately?
  5. chauhan12
    33
    6
    Jul 26, 2017
    If it is related to DPF then yes you will start loosing power and eventually truck will shut down and do more damage cost of repair can run any where from 1000 to 2500 depending on the issue if its just the sensor then you could be back on the road in few hours but if its the dirty filter then might be two to three days. Good Luck.
  6. chauhan12
    33
    6
    Jul 26, 2017
    Did you manage to get it checked out what was the issue with the truck.
