Check Engine light and Stop light goes on and blinks
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by dztruck, Jun 26, 2017.
  1. dztruck
    dztruck Light Load Member
    271
    208
    Feb 22, 2017
    hi i have a 2012 cascadia with a dd15 i bought from penske. Had if a few weeks and everything was fine. Did a run a few days ago and suddenly my check engine light comes on and the "stop" light flashes on and off. If i drive for about 3 minutes they both start flashing and the engine shuts down. I have been byspassing the shutting down by using the engine shutdown override whenever they both start blinking.
    Has anyone else had that issue? Im worried that it could need a new dpf, or at leasr a cleaning. Or could there be something else? Also engine seems to run just fine, maybe a little weaker at 35mph+. Please help!
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Geez man...
    Get the code in the ecm. It will tell you why.
    Could be anything..
  4. CJndaTruck
    CJndaTruck Road Train Member
    3,349
    3,365
    Nov 21, 2014
    Knoxville, TN (area)
    Dude it most likely is your PDF filter. And if you have been using the bypass soon you will blow your motor. Hopefully you have only ruined the filter to the amount of 3k and not the motor to the amount of $22k. Good luck, and try reading the owners manual.
  5. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Could be anything really. Check your coolant level. If it's low that will do it also.
  6. Animosus
    Animosus Heavy Load Member
    727
    2,863
    Dec 7, 2015
    SE Wyoming
    An ash clean request will not cause a shut down condition. There is something more severe going on. With no codes it could literally be thousands of causes.
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Oh he has codes. That's why his lights are on .
    pushbroom Thanks this.
  8. dztruck
    271
    208
    Feb 22, 2017
    Ok so i was low on coolant, but we filled coolant up. And now its saying "coolant temp is hot", they are checking it again to see what it is. Ive looked online so far people are saying it could be bad egr cooler or bad fan. Both seem expensive.
  9. aussiejosh
    aussiejosh Road Train Member
    4,743
    5,539
    Aug 28, 2009
    Airlie Beach QLd
    there's a reason those lights are there to warn you to check your engine it could be something as simple as topping up your oil or as complicated as a blown turbo either way you've got to get it checked out.
  10. Sidekick77
    Sidekick77 Bobtail Member
    4
    I hve an issuse with def nt making it 1 box..cant do a full regen..only air coming out of metering unit..
  11. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Don’t completely understand your post. Best I can tell it sounds like your DEF Pump has failed. Either wiring to it or pump itself.
    If the lights are flashing. You should be able to pull a code from the display on your dash. Get it and it will narrow it down.
