Check Engine Light
Discussion in 'Peterbilt Forum' started by RT76, Aug 28, 2014.
  1. RT76
    RT76 Bobtail Member
    I have a 96 378, just put in a 99 3406E and all is good except for the check engine light and volt meter.
    The check engine light blinks 5 - pause 5. Not sure what it is.
    The volt meter is only reading 13.5 volts. I have 14.3 at the alternator and 14.07 at the starter. Checked both sides of the frame mounted circuit breaker and it is the same. I don't know where else to look.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    55 means no codes. Check the wiring to the cruise switches.
    What is the voltage at the voltmeter?
  4. RT76
    RT76 Bobtail Member
    I have 13.6 at the meter. There is no cruise control. Used to be on the shifter but it was removed a few years ago
  5. stellar
    stellar Bobtail Member
    i have a newer truck and probably more tech stuff but my gas cap was loose causing the engine light on
  6. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Find the cruise swtich wires. To pull flash codes, you use the cruise swtiches, you truck is stuck in flash mode. This is probably becuase the set/resume swtich wires are shorted together.
  7. RT76
    RT76 Bobtail Member
    Thank You! cruise control wire had a short
