check fuel filter light..full davco fuel/water separator
Discussion in 'Volvo Forum' started by roguzzi81, Mar 26, 2015.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    You are supposed to add the the solution, not be part of the problem!:biggrin_25523:
  3. mladen86
    mladen86 Medium Load Member
    303
    269
    Aug 23, 2012
    Chicago,il
    [emoji3] well,try changing fuel filter housing. Its cheaper then set of injectors
  4. HwyDragon
    HwyDragon Light Load Member
    63
    21
    Jul 27, 2015
    Anyone know of dangers of driving with fuel filled to the top of the globe?
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Yeah....it bypasses filter and goes to Engine secondary that doesn't separate water.... End game = Injector damage
    If filter fills up... You should be happy ... It's doing it's job and saving your engine from the crap in your fuel system !!!!!
    Rob100100 and HwyDragon Thank this.
  6. KB3MMX
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Oh... And the "fix" isn't going to a larger micron filter and letting all that crap get sucked through their injection system to cause wear and damage!! ...
    .... The fix is CLEAN your fuel system out or keep charging filters until all the junk has been filtered out.
    If you have black slime ... You need to hit it a couple times hard with fuel BioCide to kill the slime.
    This is not the injector cleaner crap at a truck stop , it's one purpose biocide additive ...
  7. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Buy a new filter 10 to 30usd and the tool ...
    5 min jop to change it by your self
    If you cant do it take a office job
  8. GeorgeStoenchev
    GeorgeStoenchev Light Load Member
    70
    13
    Sep 21, 2014
    I have the same problem . My filter is full after 600 miles. No messages or lights on. This happened after constantly using of fuel system cleaner. I hope soon everything will be back to normal.
    KB3MMX Thanks this.
  9. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Last week I was changing filter twice a day. Getting 200 miles pert filter. I had put clear diesel in both tanks on 2 last fill ups. Then run tanks down to 1/4 tank. I think when ever you add any additive it will fill up filter. It supposed too it's foreign to the fuel sys.
  10. GeorgeStoenchev
    70
    13
    Sep 21, 2014
    I have fixed mine. Just clean you fuel tanks and everything will be back to normal. it cost me around $300
  11. KB3MMX
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    It's just crap in the fuel.
    First use biocide heavily , followed by a good dose of a cleaner.
    You'll go through a bunch of filters as they tap the bad crap from going to your 30,000 psi injectors and causing damage.
    DO NOT use a higher micron filter , it will pass the crap onto the engine.
