check fuel filter light..full davco fuel/water separator
Discussion in 'Volvo Forum' started by roguzzi81, Mar 26, 2015.
  1. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Well said. I've had filters clog fast. I used to swap mine once they hit the change line. I'd change them out in a few minutes.
    Change filter. You should keep a davco wrench and at least 3 filters on your truck at all times.
    KB3MMX Thanks this.
  3. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
  4. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Also, many fuel stops are blending biodiesel in the fuel, even in winter. When temps go into the basement, filters will clog up significantly quicker. I use a Davco and it is a piece of cake to change the filters when I need to. I carry a few spares and some fuel in a container for putting in the bowl after the filter change. I NEVER reuse fuel I drain from the Davco to change filters and NEVER put it back in the tank.
    KB3MMX Thanks this.
  5. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    You have to wonder how many early inj failures are caused by the plague of old school pre filling of engine fuel filters, especially on the high pressure systems like Volvo.
  6. RoadRanger^^
    RoadRanger^^ Medium Load Member
    314
    116
    Apr 17, 2018
    Columbus, OH
    Hello fellas,
    On my Volvo vnl with cummins isx 15 rebuild engine 100k ago, notice when idling check light is coming on. Went thru the diagnostic on the dash and it is throwing the code
    SA 0 SPN 97 FMI3. I called the dudes in cummins but they are saying that is some issue with fuel/water separetor which i never had that issue before and don’t know much about it. I tried to drain it when i was doing my delivery and till i get home it was full again. I also notice when i go on uphil with a load 40k checklight is comimg on and right away i climb the hill and take off the foot from gas pedal it goes away and like that all day. So i don’t know if it’s the same code or something because while driving that code comes and goes away. Any help would be appreciate and if fixed i will post back. Thank you!
  7. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Probably bad fuel from a truckstop, please read all of the previous posts. They are very helpfull. People gave time to answer the questions. You might find a solution to your problem.
    KB3MMX and RoadRanger^^ Thank this.
  8. RoadRanger^^
    314
    116
    Apr 17, 2018
    Columbus, OH
    I’m back guys. I did replace the fuel water separetor filter. It was black and was filling up so fast, now since i changed it, of course did it by my self cause it is so easy 5 minute job. After i changed it i fill it with clean diesel fuel and since then it stays empty. Is that how supposed to be ? I can barely see fuel on the bottom so i guess this filter is doing it’s job. Btw check engine fault light with the same code for the filter is still here. Any advice ?
    KB3MMX Thanks this.
  9. Newto Trucking
    Newto Trucking Medium Load Member
    359
    226
    Dec 26, 2013
    NE Illinois
    It will stay at the bottom for the first couple thousand miles unless you got really bad fuel. Codes conditions are rechecked at every start of the engine and after 4 hours of continuous driving. Try shutting down more often not in a traffic
  10. RoadRanger^^
    314
    116
    Apr 17, 2018
    Columbus, OH
    Okay. I just changed the oil and replace the filter again it was dirty on the bottom, anyway i will let you guys know if the code will dissapear or if that was the issue. Thank you @Newto Trucking
    KB3MMX Thanks this.
  11. Newto Trucking
    359
    226
    Dec 26, 2013
    NE Illinois
    What year is your truck and a mileage?? How old are the injectors???
