Check IGN fuse
Discussion in 'Volvo Forum' started by rogueunh, Jan 21, 2016.
  1. rogueunh
    rogueunh Road Train Member
    1,082
    22,200
    Jan 4, 2011
    Anyone had this warning come on before? I changed every IGN fuse, and at times when truck is started the instrument cluster is totally dead for a few minutes, then comes to life usually after a while.
    2003 Volvo sleeper tractor.
  3. sammaxlee
    sammaxlee Bobtail Member
    33
    Jun 20, 2019
    my truck is 2014 volvo D13 engin .i got massage "check IGN fuse " . If anyone knows .please let me know where this fuse is.I checked all fuse in the fuse box but i can not find it .thank you
  4. dc2k
    dc2k Bobtail Member
    hey did you figure this out im having the same issue
    thanks
  5. Lisbetjorge
    Lisbetjorge Bobtail Member
    Hi did you Guys find it , because my truck is showing me the same message
  6. Lisbetjorge
    my truck is 2008 volvo ISX Cummins engin .i got massage "check IGN fuse " . If anyone knows .please let me know where this fuse is.thank you
  7. brosimpson
    brosimpson Bobtail Member
    Your ignition switch where you push the key in to start the truck is the problem. Replace the ignition switch and that will fix your problem. I've had the same problem.
