FMI 16 fault code SPN 81 ( after treatment diésel particulate intake pressure use code 3609 ) —— international proststart 2015 Cummins. What do I have to do ? What is the cause ?
From your post I would assume your DPF needs to regen or be cleaned or the sensor that monitors the pressure in the DPF has failed and the computer is letting you know.
