Check transmission system at next stop light on. HELP!!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Autous2012, Nov 20, 2017.
  1. Autous2012
    Autous2012 Bobtail Member
    12
    Nov 20, 2017
    Check transmission system at next stop light on.HELP!!!!
    shreemike Thanks this.
  3. tk40176
    tk40176 Light Load Member
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Got the same problem - in the shop now.
  4. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    I guess get out and look down to make sure it is still there. That's the best info I can give you since you gave me nothing to go on. What are you driving?
    magoo68 and Goodysnap Thank this.
  5. Autous2012
    12
    Nov 20, 2017
    What you do in shop? I go to shop now.
  6. tk40176
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    2013 Volvo VNL 730w/ Ishift at 600k.
    At first the mechanic at a Volvo dealership thought it was a software issue and thought updating it was enough since the fault codes were inactive. I told them that they needed to go for longer test drive than around the building like they did the first time). Got a call at 10 PM saying that the mechanic had the same problem that I'd complained about. After a tense day, they said it was just under 2 weeks left on the warranty and said it was covered. They had to order a new transmission and should be done by middle of next week.Talk about a luck.
    flood, Heavyd and baha Thank this.
  7. tk40176
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    BTW - with out warranty, I was quoted little over $20 K. If I didn't have any warranty left I'll either replace it with a manual (not likely) or just get a low mileage used one from a salvage yard and just replace it or get rid of the truck. I love Ishift and I would rather replace the truck than loose it.
  8. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Good timing, almost like you just got 20k X/mas bonus
  9. tk40176
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Yeah, maybe it's a "make up" for the last X-mas when my custom W9 + the 53' alum step deck (on my avatar) was stolen.
  10. tk40176
    271
    154
    Apr 8, 2010
    Brooklyn, NY
    Don't know how your truck is acting up but mine:
    At first - it felt like as if the clutch was slipping then it got progressively worst. After few days - once cold it ran almost normally, after 80 - 90 miles, it starts to slip on incline / pulling up hill - I would feather the fuel pedal (few times) and it catches. It got worst and worst.
    I first noticed it around Laramie heading out west, took it to a small Volvo shop in WY, few hundred $$ later they said the codes were gone. The truck would slow (slip) down to 35 mph or so then it would engage again and off I go. There were times where I had to pull over to a shoulder and start off again or even shut off / restart for gears to engage. I delivered in Portland, OR, pick up in Tacoma, WA, final out in Surrey, BC.I pick up in Aberdeen, Wa, pick up in Tacoma, WA - with drops in Billings, Mt - Truman, MN - Minneapolis, MN - Janesville, WI - finaled out in Goshen, IN on Saturday. I camped out in Fremont, In at the Petro over the rest of the weekend. Monday I started making calls. Vomac in New Haven, IN were back up to the end of the week, towing/truck shop across the street from Petro had no faith on their skill to properly diagnose / fix Ishift and the Volvo up in MI said that they could look at it asap. I didn't even know if the warranty on my truck (transmission) was valid at the time. I've heard how dealers are making what ever excuses to void the warranty but I guess, I lucked out.
    sunbunhd11239 Thanks this.
  11. Autous2012
    12
    Nov 20, 2017
    Ok. I change all gear control sensors and wire inside transmission. Pay $3000. Working good
    shreemike and Toks Thank this.
