Check Transmission System at next Stop
Discussion in 'Volvo Forum' started by adas, Feb 20, 2024.
  1. adas
    adas Bobtail Member
    7
    Aloha, Still having this issue and have done most of the recommended fixes that are discussed here. One thing---is there a certain air pressure required to keep the transmission OK? Right now my air goes down at a stop sign to 100 sometimes 90-95. Will this cause the warning? (I find no air leaks and replaced the govenor) thanks Francis
  3. Farah2017
    Farah2017 Bobtail Member
    I have same problem problem when i put the gears air going down and come back and i don’t have air leaks,pls let me know if you fixed
