Checking fuel filter on a 2014 DD15
Discussion in 'Prime' started by Danfromwindsor, Nov 25, 2013.
  1. Danfromwindsor
    Danfromwindsor Road Train Member
    1,632
    614
    Mar 26, 2010
    Anybody have any idea how to check a fuel filter on these 2014's? I guess they used to have a sensor on bottom of fuel filter but mine dont have this. RA was kinda thrown for a loop because they thought I should have that sensor. After looking at a video from Detroit Diesel on how to check the filter on a DD15 I was able to confirm to RA that no I had no such sensor and my filter setup appears to be different than what is in the video.
  3. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    Does it have the two filter set up? If so it has a water in fuel sensor midway up the filter housing. I also has a low pump pressure sensor to check for restrictions in system. That sensor is near the backside of the fuel filter module
  4. Danfromwindsor
    1,632
    614
    Mar 26, 2010
    No sensor present. Read my original post.
  5. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    No idea on a 2014 set-up. What's your truck doing Dan? Just so you know, changing a fuel filter on one of these engines is relatively cheap... I do mine every 25,000 miles.
  6. Danfromwindsor
    1,632
    614
    Mar 26, 2010
    I was having very bad mpgs the other day so that is what got me interested in filter since cant see it like I could on my last truck. Wasnt filter just bad tank of fuel but Id still like to be able to check filter.
  7. ironpony
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Change your fuel filter anyway... the last thing you need is water freezing in there, and the injectors are very sensitive to dirt 'n crud. My experience is you'll gain some mileage back especially this time of year. You want to lube the zerks between PMs in any case...
  8. Chucktaylor
    Chucktaylor Road Train Member
    1,065
    640
    Sep 26, 2012
    Why did they ditch the clear "bowl"? I miss that from my 08 truck.
    Danfromwindsor Thanks this.
  9. Danfromwindsor
    1,632
    614
    Mar 26, 2010
    Yeah me too but this new system is very high pressures so I believe that is why.
  10. duhduh
    duhduh Light Load Member
    108
    55
    Dec 11, 2012
    Western Missouri
    Dan i have the same setup. detroit dude told me this is a mercedes filter system. go figure.
  11. FLATBED
    FLATBED Road Train Member
    well since DD and MERCEDES are both owned by Daimler anything is possible
