Checking tire pressure - how do you do it?
Discussion in 'Questions From New Drivers' started by Code Red NV, May 15, 2016.
  1. Code Red NV
    Code Red NV Light Load Member
    54
    64
    Feb 11, 2016
    How do you check your tire pressure; do you thump your tires or use a gauge?
    And what do you do if your tire pressure is low? It's not like you can just go to the normal air hose at a gas station. Can you?
    I'm just asking because I'm a new driver and I've heard about the upcoming enforcement campaign coming up June 7-9. I want to make sure I'm all set in case I get pulled out for inspection.
    2016 International Roadcheck Three-Day Enforcement Campaign to Take Place June 7-9 with Special Emphasis on Tire Safety
  3. deckeralliance
    deckeralliance Bobtail Member
    46
    21
    Apr 8, 2016
    I always use a gauge, and yes you can use any air compressor there is. Just might take longer.
    Canned Spam Thanks this.
  4. Razorwyr
    Razorwyr Road Train Member
    2,284
    2,824
    Jul 27, 2010
    Meridian, Mississippi
    Use a gauge... a thumper won't tell you exact pressure. They sell glad hand air hoses in most truck stops for about $30. You just hook it to the emergency line of the truck and "release the trailer brakes." Then you have an air compressor and a way to fill the tires.
    BUMBACLADWAR, Milo161 and justa_driver Thank this.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Get yourself one of these
    akfisher Thanks this.
  6. FlexinTarzan
    FlexinTarzan Medium Load Member
    571
    655
    Jan 8, 2012
    Stanfield, OR
    With experience you can thump a tire with a rubber mallet and tell if the tire is LOW (Under 80psi) or more than 100psi,than come around with tire gauge to see how low/high. I carry a rubber air line in the trk that I hook up to the red service line valve and than go to the cab and push in the trl valve to release air. Avoid buying those cheaper plastic coated air lines and go for the higher quality rubber hoses instead.
    crb and KriegHund Thank this.
  7. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,048
    Nov 23, 2014
    Grants Pass, OR
    Always use a guage and check them during your pretrip to make sure they are legal (90 - 110). I always keep them right in the middle at 100psi. Every truck stop sells the hose bakerman suggested for around $30 and you will never need to use one at the fuel island. The other thing those hoses are good for is taking off the head for the tire inflater and putting on a blow wand to spray out your trailer to clean it. Much faster then a broom. I bought 2 hoses and a wand for about $75 and never looked back. If you do get a hose dont buy the pvc ones they kink all the time, get the flexable ones that can streach.
  8. Moose1958
    Moose1958 Road Train Member
    15,263
    33,840
    Dec 17, 2010
    Williesburg, Virignia
    To be honest most of the time the trailers I pulled had those auto inflaters on them. It's a lot of trouble to gauge check them so most of the time I used my hammer to thump to make sure they were inflated. With experience you can get a good idea by thumping Along with a good visual check. Yes you should use a gauge but the biggest thing that will get you in trouble tire wise is the tandems rubbing against each other. DOT officers that has been around can tell by looking at your tires if you might have an under inflated tire or overloading them.
    Now to answer your question, use a gauge as much as possible. I used one but I also was comfortable thumping them too.
    G13Tomcat Thanks this.
  9. JReding
    JReding Road Train Member
    1,957
    3,510
    Sep 8, 2014
    Puyallup, WA
    My preferred weapon of choice is an old $5 claw hammer (multi-purpose, good for putting nails out of trailer floorboards, too). After a while, you develop an ear for a low tire, and then you can check the accurate pressure with your gauge.
  10. Canned Spam
    Canned Spam Road Train Member
    1,504
    2,906
    Mar 8, 2010
    STL
    According to the bossman, a boot is not the preferred method of ascertaining proper psi levels
    tucker, Blackshack46 and Bakerman Thank this.
  11. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    174
    Oct 29, 2014
    Carlingford NB Canada
    Hi
    Lol i'm lazzy ...
    Dayli kick them
    Ones a week tire pass at Love's
    Canned Spam and Bakerman Thank this.
