I have t 680 with oval amber lights running under cab and sleeper. I've seen them on many KWs and Pete's, so I'm guessing it might be a factory option. My driver side stopped working. Can anybody explain how is it wired and where is a ground located?
Chicken lights on KWs/ Petes
Discussion in 'Ask An Owner Operator' started by me myself and I, Feb 28, 2022.
Page 1 of 3
It’s usually a 2 wire continuous strand. Look at the front. There’s a broken wire in there somewhere before they get to the lights
Rideandrepair and MOBee Thank this. -
I know the ones on my 97 are scotch locked together, they like to quit and cut out and generally be a pain in the ###. They're usually grounded right to the panel in my experience, each light is actually individually grounded where it's screwed on. If the whole side is not working I'm guessing your hot wire is broke somewhere.
Rideandrepair and Vampire Thank this. -
Upon further inspection it looks like it is spliced into turn signal. And they used crappy connectors.
Of course they used crappy connectors
Rideandrepair, jason6541 and Vampire Thank this. -
Rideandrepair Thanks this.
W9 and T8 they used to be installed at the factory if you ordered them
Rideandrepair, Long FLD and Vampire Thank this. -
Is the factory into this half assery? Mine was probably not ordered with it.
Brettj3876, Cat sdp, Rideandrepair and 2 others Thank this. -
Brettj3876, Dadetrucking305, Cat sdp and 3 others Thank this.
Be
Rideandrepair, ProfessionalNoticer and MACK E-6 Thank this.
Page 1 of 3
