chn613 2006 transmission grease fitting
Discussion in 'Ask An Owner Operator' started by Mack owner, Oct 27, 2014.
  1. Mack owner
    Mack owner Bobtail Member
    I can't find the throwout bearing grease fitting. Where is it. Does it have one?
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    sure it didn't have a remote lube hose in the bottom of it that was ripped off or fell off?. leaving a hole in bottom or side of throw out bearing. not to ask a stupid ?. but have you removed inspection cover and looked at the bottom of throw out bearing to see if it might have been broke off by some grease monkey that may have jerked the grease gun off instead of pulling it off the fitting?. can't imagine it has a sealed lubed for life bearing installed.
