choosing a gear ratio.
Discussion in 'Experienced Truckers' Advice' started by CuJT Pres., Feb 15, 2018.
  1. CuJT Pres.
    CuJT Pres. Bobtail Member
    8
    Ok guys,
    looking at buying a used truck, this would be my first truck to lease back to my current carrier until it is paid off there is:
    Prostar Eagle
    cummins isx15 450 that can be opened to 475.
    22.5 lo pro
    FO-16E310C-LAS
    1650 lbs. ft. [2237 Nm] 10 forward, 2 reverse
    Transmission is an Ultra shift plus due to my disabilies. And lack of coordination.
    You want the numbers from the LAS 10C line for any calculations.
    I live in Washington and work out of Iowa so my primary lane is Seattle to Chicago and back hauling 35,000 to 44,000 in a reefer both ways.
    I would like to cruise through WI, MN, SD, WY at 72mph but under 1350RPM, and still have enough torque to get up and down the mountains of WY MT ID WA with out holding up traffic too much currently the gear ratio is 3.36 Meritor axels. There are also some runs to the east coast on I-80 if I am not ready to go home.
    Would anyone sugest changing it, and if so, Why?
    Is it smart to turn up the HP on the engine or does that put something at a higher risk?
    The truck has 540,000 miles on it getting 6.8 mpg.
    Thanks for your input
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Sweet spots for that ISX is 13-1500. Its not like a cat where you can pull them all day at 11-1200.
    With the numbers you gave above. Lp22.5 3.36 rears 1500 should put you right about 72.
    Tall 22.5's 3.36 rears at 1400 should give you about 70-72mph.
    Any higher gearing will kill you big time in the hills sense you are going with a 10sp. So a tire change might be the easiest way to see if the truck does better at a lower RPM.
    CuJT Pres. Thanks this.
  4. Russian Rabbit
    Russian Rabbit Road Train Member
    1,701
    1,633
    Jan 3, 2016
    What rpm does the engine make peak torque at?
    How serious are the mountains on your route?
