cigarette lighter plug in inverter
Discussion in 'Questions From New Drivers' started by oldog1984, Jun 3, 2015.
  1. oldog1984
    oldog1984 Medium Load Member
    442
    209
    Apr 17, 2010
    columbus,ohio
    he guys can you tell me of a good cigarette lighter plug in inverter and what all you can run off it?? thanks for any help..
  3. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    the lighter circuit should br OK for upto about 400 to 500 watts,,go to walmart and get one,,it will run a tv, power cell and computer charges etc,, any thing larger and it would be best to wire direct to the batteries,,be careful and don't run the cables out the door to the batteries,,slamming the door hard will short out the cables and either weld the door shut of at least make a lot of sparks fly,,many companies do not allow inverters,,check with your company,,,
  4. KenworthGuyNH
    KenworthGuyNH Road Train Member
    1,050
    2,686
    Dec 11, 2011
    Central, NH
    LMAO!!!!!!!!!!!
    Yeah, you will be fine though if ya just don't slam the door....
  5. DocHoof
    DocHoof Light Load Member
    160
    81
    Sep 2, 2014
    Here's the $64,000 answer...amps (times) volts = watts. So figure this:
    Appliance needs 5 amps. A * V=W, in this case we are 5*120=600. You need a 600 MINIMUM watt inverter.
    And the other kicker? Most inverters have a max rating, but only run 80% over long usage (5 minutes). So realistically, to run a 5 amp appliance SAFELY, you should be at 800 or better. Just bite the bullet, spend about $400 and buy a 3,500 watt inverter and direct wire it to your battery.
  6. oldog1984
    442
    209
    Apr 17, 2010
    columbus,ohio
    some company do not allow direct wire that's why i was asking about plug in but yes you are right direct wire would be a lot better thanks.. main thing i would like to have is my coffee pot thanks guys keep posting
  7. SCtruckerdude
    SCtruckerdude Bobtail Member
    45
    38
    Oct 17, 2013
    That's outstanding. I'm surprised a truck driver would know this. Were you an electrical engineer in your former life or what? Now if you could provide a formlua for voltage drop across the circuit I would truly be impressed.
  8. Moosetek13
    Moosetek13 Road Train Member
    14,544
    18,071
    Nov 1, 2010
    Burnsville, MN
    And like I said in your other post, a 400W inverter will only operate at 150W when plugged in to a 12V socket.
    All that stuff about Amps with a 120V appliance doesn't apply when you are using a 12V socket, until you amp it down to 12V. And then, it is no way.
    Strider Thanks this.
  9. mrdot
    mrdot Light Load Member
    241
    206
    Mar 4, 2015
    I have a small 400w continuous 800w peak inverter out of a truck stop that plugs into my dc outlet. Works great for my tv whenever I can find the chance to watch it. But that's the biggest thing I use on it.
  10. mrdot
    241
    206
    Mar 4, 2015
    That will work just fine for a coffee pot!
  11. oldog1984
    442
    209
    Apr 17, 2010
    columbus,ohio
    does it plug in to cig lighter? if what brand and model thanks for posting
