Class A air brakes road test question.
Discussion in 'Questions From New Drivers' started by sirstealth, Nov 22, 2013.
  1. sirstealth
    sirstealth Bobtail Member
    27
    10
    Nov 22, 2013
    Mass
    Hi, I currently have a Class B with air brakes and I want to get my A. I have a road test booked but the only truck I have to take the test with is a dump truck (with air brakes) and a 14k GVW trailer that doesn't have air brakes (or any brakes). Is a setup like this allowed for a class A license since the trailer is over 10k GVW? My concern is that since it doesn't have air brakes the cop wont let me test in it, however, I already have the air brake endorsement from the class B so I don't know if I can get by without it on the trailer.
    Also wondering if they give you a restriction on your license for using an automatic truck now?'
    thanks.
  3. driver7702003
    driver7702003 Medium Load Member
    300
    51
    Nov 12, 2011
    FLORIDA
    if you have the airbrake on youre b it should go onto youre class a
  4. sixpackbill
    sixpackbill Light Load Member
    114
    29
    Oct 6, 2010
    hamilton on.
    depending where your from you might have restrictions for the automatic AND possible restriction on the A for having a 14 k trailer
  5. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    In NY state, you will be restricted to a class A truck-trailer only. You have to take the test in a semi to be able to drive a fifth wheel trailer. When I bought my new log truck and pup in 98, thats what I took the test with and had that restriction. You need to find out from your state how the test works for you.
  6. sirstealth
    27
    10
    Nov 22, 2013
    Mass
    I'm in Mass, where can I go to check about the automatic restriction?
  7. biggare1980
    biggare1980 Medium Load Member
    344
    192
    Apr 29, 2009
    Springfield, Ohio
    Try the states dmv website and do a search. If they have it it "should" be there or you can try calling the main office of the dmv.
  8. Ridgeline
    22,613
    120,203
    I really do not think the trailer matters, the truck does. You shouldn't have any restrictions if you test with that combo because I can not find a word about testing with a trailer that doesn't have air brakes or a fifth wheel.
  9. ke5adb
    ke5adb Light Load Member
    65
    21
    Dec 30, 2012
    Stillwater, Ok
    If that trailer doesn't have any brakes, I wouldn't even let the DOT man see it, I'd be surprised if they don't put the trailer OOS. When I took my road test 16 years ago, I took the test in a dump truck with a pintle-hook equipment trailer (with air brakes).
  10. Allow Me.
    10,724
    12,418
    May 28, 2009
    Rancho Mirage, Ca.
    You're going to have to show the tester your trailer is safe. That means showing him it has brakes. Also, to get a CDL "A", you need to test with a trailer over 10,000GVW. I believe a road test in an Automatic will restrict you to Auto only on your license.
  11. sirstealth
    27
    10
    Nov 22, 2013
    Mass
    ^ the trailer is over 10,000GVW, and it does have electric brakes but I'm 90% sure that they don't work. How would you even go about testing electric brakes, only thing I can think of is jacking up the trailer and trying to spin the wheel but I doubt the cop would make me do that lol? I understand this combination is less than ideal but it's all I have at the moment. My test is next Tuesday and my boss will be pretty pissed if the trailer gets put OOS. Thinking about canceling now but I don't know if I should just try it and hope for the best.
