Cleaning a fuel tank
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gafred99, Feb 13, 2017.
  1. gafred99
    gafred99 Light Load Member
    155
    12
    May 28, 2009
    Tignall
    On the filter subject "Do not remove" I replaced it with a long CAT filter. It also has a frame mount Davco any fuel flow issues doing that? it is a 97 3406E. thanks for all the responses.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Bad is when you decide the 621 loader ( thirty years old ) has algae In the tank. After fighting that for three weeks (kileem) and installing a cleanable screen filter filter decided to treat the 10,000 gallon storage tank. Want to keep the from happening to the new equipment don't you know.
    Then the bulk tank filters required frequent changes and everything on the farm was coming to its knees. Even the brand new trucks and tractors were dying and yes it was planting season.
    My suggestion is to use an algaeside on as close to a full tank as you can coming home. Want it to be low on fuel when you get home. Let it set a day or longer and drain the tank. Flush it out with some more fuel and dump that trash in the waste oil. Pressure washing the tanks out is also good but than you way want to point a torpedo heater on them to remove the water.
    Also saw a similar situation when changing to bio fuel. That appears to be a good algaeside as well. Hear say is that up to 2% bio can be in the fuel you buy and not require labeling. If all of these factors are correct you could be buying you problem, you know, from storage tanks. Might want to buy somewhere else for a little while. Your supplier may not know either.
    gafred99 Thanks this.
  4. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    I used trailer bright to clean my tanks pour about half gal in tank fill it with water let it set awile I drained mine out in the field at my place when done
    gafred99 and BoxCarKidd Thank this.
  5. gafred99
    155
    12
    May 28, 2009
    Tignall
    Heck of an idea
  6. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    they will be cleaner inside than out works
  7. Deecutta
    Deecutta Bobtail Member
    13
    Jan 16, 2016
    Did you disconnect your fuel tanks?
  8. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    I did one tank at a time fuel lines were unhooked but it does a exelent job
    Deecutta and gafred99 Thank this.
  9. gafred99
    155
    12
    May 28, 2009
    Tignall
    I took a look at my lines from the tank, look like JIC 37 degree, Summit sells a pack of 40 plastic caps of various sizes. They should hold up for the duration of a soaking.
    Deecutta Thanks this.
  10. kitCat
    kitCat Light Load Member
    97
    38
    Oct 13, 2013
    Just use Fppf Killem biocide, it will get rid of all of it. Just read the instruction on the bottle of how much you're supposed to use per tank. You won't be disappointed the product is awesome.
  11. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    killem does not work as fast tried it just clogs filters
    gafred99 and Deecutta Thank this.
