Cleaning glass in blindspot window?
Discussion in 'Kenworth Forum' started by w9l, Aug 18, 2021.
  1. w9l
    w9l Medium Load Member
    316
    514
    Oct 12, 2013
    On our 2014 W900L the foot window in the bottom of the passenger side door needs the glass(es) both cleaned on the inside. Has two planes of safety glass you look through. One mounted in the exterior of door skin. The other is flush with interior door panel. Just like to get it clean as it has had dust in there get misted with soap or water at truck wash. Anyone experienced with this? Thx
    D.Tibbitt and BigBob410 Thank this.
  3. BigBob410
    BigBob410 Road Train Member
    5,665
    74,101
    Feb 2, 2016
    Beirut on the Bay, MD.
    The 389 I was in had the same issue. It wasn’t to awful hard to take the inside glass out of the gasket, GINGERLY!!, clean the glass and reinstalled. Not sure if the W9 is the same procedure or the same inboard gasket. The leak down between the glass felt is what dirtied it.
    w9l and Roberts450 Thank this.
  4. '88K100
    '88K100 Road Train Member
    1,411
    3,257
    Aug 23, 2020
    if the glass is set in rubber gasket you should be able to remove easily with cotter pin puller.
    Locked myself out of '84 COE a few times,,,removed single pane blind spot glass with pocket knife to gain entry.
    w9l Thanks this.
