Cleaning out trailers
Discussion in 'Experienced Truckers' Advice' started by SteveScott, Dec 2, 2018.
  1. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    So I have a new reefer trailer with the deep grooved aluminum floor. I only haul pallettized goods and there are always chunks of wood laying in the floor grooves that are nearly impossible to get out with a broom. Went to Home Depot and bought a $50 cordless leaf blower and it works like a charm. Gets the trailer much cleaner than a broom ever did. Just have to wear a face mask because of the crud getting blown around.
    Now I'm trying to figure out something to catch the wood pieces as they blow to the back of the trailer. Some kind of net stretched across the open doors that will allow the dust to pass through, but catch the large chunks. Any thoughts?
  3. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    I see most people with leaf blowers just blow the crap onto the ground and drive away. Drives me crazy. So thanks for not doing that!
    That said, I don’t really have an answer on how to do it...
  4. keebler13579
    keebler13579 Heavy Load Member
    988
    1,970
    Nov 16, 2012
    Take it to washout facility let the deal with it
  5. SteveScott
    4,897
    16,809
    Nov 10, 2015
    Yeah I've seen that too. Lazy and illegal. Dust and a little dirt is okay, but some guys dump broken pallets and all kinds of crap on the ground.
    Kyle G. Thanks this.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Another option is to get a SOFT BRISTLE push broom at Walmart or Lowes and keep it on the back of the cab. The soft bristle can be worked down into the grooves then pushed to the back about 5 times to get most of the larger particles. Then use a small 7/8 inch putty knife to get the wood bits out of the grooves, into your gloves, then into a trash can.
    You can possibly skip several washouts by sweeping or blowing out but don't let the left-behind smaller dirt and grime build up too long if you do run refrigerated loads on occasion. Granted some loads are dirtier than others and use your discretion if later going after a food load. This accumulated dirt, dust, and grime will hold moisture and foster mold growth in closed trailers when left out on warmer days.
    Always run the unit and keep closed [after dropping a frozen load] to dry out the inside good before dropping. After frozen loads, a lot of condensation moisture will form and later foster mold/mildew. It's important to rid the floor and walls of this moisture soon after unloading.
  7. Moosetek13
    Moosetek13 Road Train Member
    14,942
    18,950
    Nov 1, 2010
    Burnsville, MN
    You could blow everything to the front of the trailer, then scoop it all up into a trash bag.
    One more blow out to the rear will get rid of any dust.
    kylefitzy Thanks this.
  8. SteveScott
    4,897
    16,809
    Nov 10, 2015
    I actually have a soft bristle push broom, but some of those pallet pieces get wedged and just won't budge.
    I don't really haul frozen food loads so everything stays dry and pretty clean. For the most part it's just crap that breaks off of pallets and dirt from forklift tires that I need to blow out. It's a new trailer and I doubt if I'll have to do many or any washouts for a very long time.
  9. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Some of those blowers are also vac's they are more expensive but solves your problem
  10. Moosetek13
    14,942
    18,950
    Nov 1, 2010
    Burnsville, MN
    Powerful and big enough to suck up large chunks of wood?
    I doubt it.
  11. 062
    062 Road Train Member
    6,321
    33,958
    Oct 20, 2013
    You could carry a trash bag and pick up the big stuff on the way to the nose of the trailer to blow it out. For the wedged in stuff just use a screwdriver.
    KDT Thanks this.
