cleaning soot from inside exhaust
Discussion in 'Experienced Truckers' Advice' started by Coolbreezin, Jan 8, 2017.
  1. Coolbreezin
    Coolbreezin Medium Load Member
    404
    422
    Jun 11, 2016
    Florida
    When I start my truck little black flakes come out of my exhaust. Like black snowflakes. I was told by my mechanic that I need to clean out the pipes, like a chimney sweeper of old. Ive racked my brain on what I would use for that sweeping. Only thing I could think of was getting a ceiling fan blade cleaner and bend the bristles into a round shape. Any advice?
    Plus: are these flakes an indicator of an engine issue? 1991 379, 3406b engine.
  3. belowspeedlimit
    belowspeedlimit Medium Load Member
    648
    611
    Oil country
    Hire a lot lizard to suck on them
    TGUNKEL and AtticusRoad Thank this.
  4. Ridgeline
    22,633
    120,551
    Why don't you just take off the albow at the bottom of the stack and clean it out there?
  5. Byx
    Byx Light Load Member
    150
    225
    I used a rotary tool and a wire brush to clean out my uncle's stacks for him (he payed me 300$). They looked brand new when they were done
  6. bzinger
    bzinger Road Train Member
    16,635
    66,093
    Dec 10, 2014
    omaha , ne
    I think your mechanic is pulling your leg .
    passingthru69 and Roger McG Thank this.
  7. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    Did the mechanic say why it was necessary to have the soot cleaned from your pipes?????????
  8. shovel98
    shovel98 Light Load Member
    251
    241
    Jan 15, 2011
    mn
    Muffler belt must be slipping tighten it up. Go get a chimney sweep brush you can drag it thru sections. Don't know why it would matter its a b model its going to create some soot. I would be more worried if it stopped doing it.
  9. Coolbreezin
    404
    422
    Jun 11, 2016
    Florida
    Ridgeline: Good point. He told me that the heat and pressure would send most of the soot to the exit of the exhaust. Makes sense.
    Roger McG: He didnt say it was necessary to clean them out. Just thought it should be something I do as general maintenance. Plus I wasnt sure if the flakes were a sign of something wrong.
    Personally, I dont like the black crap on my stacks or top of my sleeper.
  10. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    If this is a serious question rain caps will help. The rattling might drive you crazy though. That or plastic pails when parked for a couple days. Mufflers will cut down on that too. But like the others said a mechanical cat will always be prone to doing that. My old truck got a lot of quick rinses with the washer because of that lol
    Hammer166 Thanks this.
  11. Coolbreezin
    404
    422
    Jun 11, 2016
    Florida
    I am being serious. I always liked the look and tinging sound of the caps as I grew up. I do plan on getting the caps when I cut the stacks a little shorter. It looks like King Kong took a horrendous dump on top of my sleeper (black soot running down sides when wet).
