Cleaning soot from intake system
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Cruisser, Nov 17, 2015.
  1. Cruisser
    Cruisser Bobtail Member
    19
    6
    Dec 12, 2011
    Aberdeen, SD
    I am curious if anyone can give me an idea what it costs to clean the soot and replace the sensors on my ISX engine. The mechanics I have talked to so far won't give me a quote, just say they charge by the hour.
    I had an exhaust leak that did not let the turbo work correctly and now the inside of my intake and sensors are covered with soot. I know this has to have a big effect on my mileage, not to mention the longevity of my engine.
  3. AModelCat
    161,267
    If its a newer EGR engine, that soot is likely due to the nature of the EGR system. Most times the intakes on EGR-equiped diesel engines are sooted up as bad as the exhaust. I wish I took pictures of an Isuzu 6HK1 I rebuilt. It took me a minute or 2 to identify which ports were intake and which were exhaust.
    Cruisser Thanks this.
  4. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    What Northern said.....soot is normal on an EGR engine and yes it looks bad but that's what we're stuck with. A local utility company USED to clean soot deposits from the intake of their small Cummins engines until they left a hardened chunk laying loose that they knocked off and it caused piston/valve contact and major repair dollars.
    Cruisser and KB3MMX Thank this.
  5. 062
    062 Road Train Member
    6,274
    33,779
    Oct 20, 2013
    It's not complicated work. Basically disassemble clean reassemble. You will need a couple big wrenches,compressor pipe will be like 1 1/2, don't lose o-ring. Sensors anywhere from 7/8 to 1 3/16.
    Look for "rawze egr tune up" on YouTube
    spax and Cruisser Thank this.
