Clearance lights won't come on
Discussion in 'Peterbilt Forum' started by 377pete, May 16, 2012.
  1. 377pete
    377pete Light Load Member
    147
    14
    Oct 26, 2009
    dfw
    This morning when I started the truck, I turned the headlight o. And clearance light on also. Separate switches for both. They all came on. Went inside and 10 minutes later they where off. Fuse is not blown and the switch works because when I flip it it turns on the lights at the gauges . Any other place I should look?
  3. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    The switch is multi terminal using independent terminals for dash and clearance lamps so it could still be the switch or a ground issue.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    There is also a bulkhead plug behind the glove box that feeds all the roof section I have seen terminals work loose there.do you have a fuse or a breaker petes have a problem with leaking winshields that allow water to damage the back of the fuse box.but I would start with benders advise and check the switch first
    bender Thanks this.
  5. 377pete
    147
    14
    Oct 26, 2009
    dfw
    Thanks guys. It was the switch
    bender Thanks this.
