Clicking noise
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckerPete1990, Sep 3, 2020.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,381
    Jul 16, 2012
    Bentonville Arkansas
    I Have a clicking noise coming from near the front driver side area.. I Have checked the steer axle for any kind of play and nothing. I jacked up the front steer and spun the wheel by hand to see if that's what's make the noise its not. I Can hear this noise from 1-45 MPH till the wind gets loud enough to cover it.. Best way to describe this noise is a Zip tie hitting something... I Have checked for anything loose and fixed any clamps that where hanging down. Faster i go faster i hear it so its speed related.. Its a 2014 T680 Could this be something in the drive shaft? The drive shaft is tight..
  3. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    Loose wheel bearing? Jack it up, and from the top of the tire, push and pull like you're trying to pull the tire off the rim. Sounds funny, but you really got to put some weight into it. Learned that from experience...
  4. TruckerPete1990
    8,623
    5,381
    Jul 16, 2012
    Did that tonight it's tight no movement at all.
  5. skellr
    skellr Road Train Member
    8,735
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Do you hear it when parked and rev up the motor? Or only when moving?
  6. TruckerPete1990
    8,623
    5,381
    Jul 16, 2012
    Only while moving I'm gonna try to pull my covers off tomorrow after I get done rewiring my CB and see if it's still there. Maybe it's a hub cap issue.
    skellr Thanks this.
  7. AModelCat
    161,441
    No rocks stuck in the tread?
  8. TruckerPete1990
    8,623
    5,381
    Jul 16, 2012
    No just weird outside wear on this tire I'm wondering if the wear isn't causing it. This wear started before I had an alignment done. Just haven't replaced the tires yet.
  9. wadeenterprisesllc
    wadeenterprisesllc Bobtail Member
    11
    6
    Jun 9, 2022
    Did you figure out what it is? Mine is doing the exact same thing after putting a new wheel seal on the front passenger side
