clicking Relay
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Jul 31, 2013.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    Well my relay for the A/C compressor in my fuse box is clicking? Why would this be? Freaks me out a bit. Don't want flames shooting out of there..
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,732
    Jan 30, 2010
    keep stroking.
    you have a short or it has gotten weak from the heat and is clicking off sooner than it should. replace it and see what happens. if it still does it then you will have to look else where. check the blower switch or resistor(it is in the a/c heater air box) or maybe your blower motor is dragging causing to much draw on the circuit.
    brenes-built and Kansas Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,808
    6,256
    Feb 4, 2009
    They are supposed to click. Do you mean it is rapidly clicking? If it is try to swap it with another one to see if the problem is the relay or the circuits.
  5. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Superhauler has it right. They get old and weak from heat and repetition, first step is a new relay. Eliminate that possibility and proceed from there. Cheap enough...
