ClimaCab Battery Powered APU
Discussion in 'Schneider' started by COVE, Aug 29, 2014.
  1. COVE
    COVE Bobtail Member
    15
    Mar 2, 2014
    Columbus, OH
    Hello everyone. I was approved to come on board Schneider's Choice program. I'm ready to get started and put in my 2 week notice at my current job, but having some issues finding a truck through SFI. There are tractors available, but they all have the battery powered APU called ClimaCab. Personally, I would rather have a diesel powered APU like the Tripac. I just can't see the battery powered APU handling the load of an A/C cooling the cab & other devices running. I can see needing to get up every 6 hours to idle the main engine to charge the batteries. NOT GOOD!!!
    Does anybody have any experience with the battery powered APU called ClimaCab?
    Thanks...
  3. TennMan
    TennMan Road Train Member
    7,866
    9,658
    Sep 21, 2011
    Hazzard County Jail !!!!!
    not the clima cab but I do have a battery apu and so far so good it lasts about 12 hrs unless its on hi then about 9-10
  4. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    Yes , my last truck had a Clima Cab
    Clima Cab simply cannot handle high or extreme outside temps
  5. Balakov100
    Balakov100 Road Train Member
    3,937
    2,636
    May 10, 2012
    Temple, TX
    ClimaCab I had, was not designed to provide ANY KIND of in cab power.
    Heating and Cooling only.
    It did have a button you could press to discharge the ClimaCab and charge the Truck batteries in case it would not start.
  6. moosc
    moosc Road Train Member
    3,284
    1,172
    Mar 5, 2009
    Lincolnton NC
    You'll to find a older truck with a tripack or get kw t680. But you'll need to put 5k down in it
  7. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    Parksmart (freightliner or western star)or climacab (cummins) are not battery APU's. There solely for HVAC reducing or eliminating the need for idle time.
    external diesel fired power units or battery powered units provide 120 v POWER and HVAC capabilites without idle.
    TennMan and moosc Thank this.
  8. stevep1977
    stevep1977 Road Train Member
    3,699
    22,306
    Dec 23, 2010
    Chicago, IL
    You can get whatever diesel powered APU you want on a NEW tractor, cascadia, kw, etc, but you have to work that into the payment structure. You don't necessarily have to put anything down to get a diesel APU. If you are going used it's whatever that tractor is equipped with
  9. dieselfuelonly
    dieselfuelonly Road Train Member
    2,475
    5,086
    Nov 12, 2012
    Chapel Hill, NC
    Not all of the diesel tripacs come with the inverter (its an option), mine doesn't have it. They are still great units but be prepared to drop some $$$ on an inverter if the unit you get doesn't have one.
    TennMan Thanks this.
  10. joec43
    joec43 Bobtail Member
    39
    6
    Jul 8, 2009
    Charlottetown, PE
    does anyone know of a tech that knows anything about these units?
    I have a 1.5 and its acting up, took it to a Cummins dealer down south (they won't even look at it in Canada), and they just want to replace everything, with no assurance it will work.
    I need to talk to someone that actually knows how to repair it!
    Any and all advice accepted.
    Can't even find a forum for these.
  11. joec43
    39
    6
    Jul 8, 2009
    Charlottetown, PE
    also if anyone knows of one for sale, new or used, I am interested
    Joe
