Climbing long grade; truck starts to shake and losses power
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by TruckNorris, Jun 9, 2017.
  1. TruckNorris
    TruckNorris Light Load Member
    71
    20
    Apr 7, 2012
    Oshkosh, WI
    Ever since I've owned this truck sometimes on a long grade when I would downshift to 12, then reach the top and go back into 13th the truck would shake and have little power for the first few seconds, then it would go back to normal.
    3 weeks ago I had the motor overhauled and now it seems to do it more often, and this morning it did it in 13th while climbing. Bad shake, loss of power. I was able to pull off on the ramp and let the truck cool down a bit, and it was fine for awhile after that.
    So what would cause this? It's only happening when the truck is really working and getting warm, I'm thinking the Clutch? Getting warm and slipping?
    Truck is an 06 387 with a 600hp C15, Eaton 13 speed. Any ideas?
    Oxbow Thanks this.
  3. belowspeedlimit
    belowspeedlimit Medium Load Member
    648
    611
    Oil country
    HP shortage??
    Oxbow Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,472
    6,509
    Aug 26, 2014
    2nd the clutch, watch RPM close when it does that.
    Oxbow Thanks this.
  5. TruckNorris
    71
    20
    Apr 7, 2012
    Oshkosh, WI
    Well, only an hp shortage when it starts shaking, otherwise since the rebuild the only thing that slows me down on the hills are idiot drivers who can't pull em :p
    I'll watch the rpms, also going to see if I can angel the clutch next time it happens. I took a lighter load to hopefully get me out of her without issues though so we'll see what happens.
    Oxbow Thanks this.
  6. Zigzag777
    Zigzag777 Medium Load Member
    460
    514
    Mar 25, 2013
    Down Yonder
    There are just too many things that could be the cause. I would highly recommend an engine scan (assuming you have an electronic engine), to see if there are any codes, or incorrect settings and maybe a spin on the dyno might help. How heavy are you on the hills? Also was the overhaul done by a shop that you know and trust? As you might want to go elsewhere for this problem. 600 hp should be good for just about any hill.
    Good luck
    Oxbow Thanks this.
  7. TruckNorris
    71
    20
    Apr 7, 2012
    Oshkosh, WI
    It did it before the rebuild as well, so my thought was it isn't engine related, I have a code scanner and nothing has shown up yet, other than a slight valve cover gasket.
    As far as the shop goes, this is a nationwide Kenworth shop, and frankly one of the only places I would let touch my motor anymore. Todd's the man there.
    I'm usually 78-80k. Normally don't have issues unless I'm in a bit nasty hill (can cross Pennsylvania at 80k without down shifting once.) Yesterday I was 78,500 and losing 15 mph once it started acting up in average hills.
    Oxbow Thanks this.
  8. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Just a wild stab at it. But years ago, Ran a tri-Axle that did that. And after weeks of trying to figure it out. Turned out to be the charge air cooler. Guess the extra heat in it, allowed the crack to open up under heavy boost.
    One other time guy that hauled with us. His pressure plate was causing an issue like that also.
    Pete
    Oxbow Thanks this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Old rubber fuel hoses swelling on the inside?
    Oxbow Thanks this.
  10. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Im guessing clutch too. Especially sense it did it before the rebuild and is now worse afterwards. The rebuild probably uped the horse pressures just a little bit and now the clutch is angrier. Try adjusting it and if that dont fix it it's probably time for a new one.
  11. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    We had a similar issue with a Detroit a few months ago.
    Turned out to be a clogging fuel filter, changed the filter and it went away. I think we had a bad batch of fuel, causing the problem.
