Here we go again. 1999 Freightliner Century 12.7 detroit with 1.5M miles. I grab the steering wheel when climbing in and out of the truck, and now it makes a “clunk” sound when pulling down on steering wheel. Research seems to suggest it is a bad steering shaft, but could also be u-joints. What have you guys experienced? Thank you for any info.
Clunk from pulling down steering wheel
Discussion in 'Experienced Truckers' Advice' started by RepoweredRookie, Feb 22, 2024.
Steering shafts are easy to replace. They do wear out. The U joints are part of the shaft. Without looking I don’t think they can be replaced separately. Steering assembly is not easy. Not hard, just annoying. This was on a 98 FLD. Yours shouldn’t be too much different.
exhausted379 and RepoweredRookie Thank this. -
Just looked at another guy’s thread. On Freightliner Century, the u-joints are non-replaceable and come as part of the shaft. Shaft (upper) is $650. Guy in other thread ssid Freightliner wanted $1200 for upper and lower.
RepoweredRookie, Diesel Dave and exhausted379 Thank this.
My entire steering column is loose. I got one from a junkyard because my other one was really bad. Now this one has become looser. I think it needs tightened somewhere that I haven’t tried.
RepoweredRookie and exhausted379 Thank this. -
Oh, I wouldn't mess with anything steering, pretty important. Pay whatever, get the new shaft, before YOU get the shaft. Clunking or clicking is a U joint or spline going south and you may not see it. Years ago you could replace just the u joints, but seems an easy fix for something that could be a disaster.
RepoweredRookie Thanks this. -
I'm not trying to be a wiseguy by any means because there's enough of that on this forum the way it is. But you might want to find something else besides your steering wheel to pull yourself up in the cab. I'm pretty sure you can put grab handles on. Just my two cents.
RepoweredRookie, Long FLD and 062 Thank this. -
Lubricating the intermediate steering shaft with white lithium grease has helped me out in the past with “light” clunks.
