Clunking sounds
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nash009, Jul 19, 2011.
  1. nash009
    nash009 Bobtail Member
    4
    houston, tx
    Hi ... I am driving a 2008 pete 387. Everytime I turn the steering wheel sharply to the left or right, there's a clunking sound from underneath the truck. No problem driving it straight. Anyone have an idea what's causing this?
  3. kajidono
    kajidono Road Train Member
    6,422
    4,659
    Jun 1, 2009
    Streetrat
    Not sure what the real name is, former boss called them kingpins. They're part of the steering linkage and the clunking is an indication of them wearing out. I think if they only make noise when you have the wheel turned as far as it will go, they'll probably still last quite a while so it's not like they're going to fall off just yet. At least I've never had one fall off.
  4. nash009
    4
    houston, tx
    OK ... question. What happens if they do fall off while driving??
  5. kajidono
    6,422
    4,659
    Jun 1, 2009
    Streetrat
    I think your wheels will do things independent of you and each other until many loud crunching sounds bring you to a sudden and very uncomfortable stop. I'm not a mechanic so I just have a rough idea of what they are. I have driven trucks that clunked and popped like that for many thousands of miles without anything letting go.
  6. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I think you are refering to the tie rod ends. Kingpins are not part of the steering linkage and would never fall off.
    When you hear the clunk can you feel it in the steering wheel?
  7. nash009
    4
    houston, tx
    No. The steering wheel acts normally. There is no resistance, just that there's a distinct loud clunk sound when the steering wheel is sharply turn (left or right). Even at highway speed when steering is moderately turn, but especially at low speed when I am making a sharp left or right turn and more noticeable when I am heavily loaded.
  8. I_HATE_MINIVANS
    I_HATE_MINIVANS Heavy Load Member
    A steering component making a clunk would probably give you feedback in the wheel.
    I don't know about your KW but I do know that lots of Volvos have a clunk in the leaf springs when turning a corner. I don't know exactly what causes it but I was told by several mechanics "oh, they all do that, don't worry about it".
    Is this something new that's never happened before?
  9. nash009
    4
    houston, tx
    I can't say this is normal, since I've driven several different brand truck b4 (except Volvo) ... and never have a similiar experience. It happened before, then the truck was brought in for new steer tires and wheel balancing. The problem went away for a month, and now is back.
  10. trucker_101
    trucker_101 Heavy Load Member
    941
    639
    Apr 23, 2010
    Alberta
    check your steering box & make sure it's tightly bolted to the frame. while your there grab your steering shaft if you haven't already, and wiggle it to the left & right like you were driving & see if you can see anything or hear anything.
  11. SL3406
    SL3406 Medium Load Member
    550
    1,482
    Jan 10, 2011
    Oklahoma
    I think you're hearing the front springs sliding side to side hitting the shackles. I also have a 2008 Pete which has non greaseable pins and bushings in the front springs and my springs don't move side to side. If your truck is equipped the same the bushings may need to be replaced to stop the movement.
    JohnP3, I_HATE_MINIVANS and Cetane+ Thank this.
