Cluster goes dead and losing engine power
Discussion in 'Volvo Forum' started by Ceciljr, Jan 15, 2013.
  1. Ceciljr
    Ceciljr Bobtail Member
    Hi , can anyone help me, I'm an automotive technician by trade and I'm trying to help a friend with a 2004 Volvo vnl with a cummins isx, the main problem he has is his cluster will go dead and then he will lose engine power, I checked codes through his cluster and he had mid 128 sid 231 fmi 19 (data link j1939) and code mid144 sid 230 fmi 15 stored in vecu(idle validation switch) this condition only happens for the matter of seconds and cluster comes back and engine works fine, I've been check the data wiring for faults with no luck, any help would be appreciate
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    Sounds more like an ignition switch problem, or the wiring at the back of the switch. That is what I would look at first if it was a Freightliner, Volvo's ???
    Just a thought!
  4. Super Wayne
    Super Wayne Bobtail Member
    23
    6
    Sep 14, 2011
    Oklahoma
    Check battery cables. Make sure all the nuts on the battery posts are tight.
  5. h21racing
    h21racing Bobtail Member
    i am having simular issues with my 2000 vnl64 660 with d12 motor but not only am i losing my dash but the dash fan motor and the wipers?
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    sounds like relay problems ore wiring problems. usual for Volvo
  7. Ceciljr
    I too believe it is wiring but it doesn't give u much time to check it, I did notice this morning when it was dark I did lose my exterior light and panel switches backlighting at same time cluster went out, the after market stereo stayed working, I also had the Cummings scan tool on at this time and it lost communications with ECM, I don't have very actuate wiring diagrams to draw a common problem
  8. Ceciljr
    Found problem to be ECM ground close to battery, it must branch off else where to give cluster and light module a ground,not sure if I was losing wipers and fan motor but would be worth checking this ground on yours
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    yep, it is ussual problem for volvo, corroded thin wires on batteries
