Clutch comparison
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bigguns, Feb 3, 2020.
  1. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Comparing a 7 spring and a 9 spring clutch:
    why 2 different set ups and the pro and cons of each.
    I like a Solo clutch because when they work properly the clutch feels the same day after day. Yes I am all too familiar with the problems with the early ones. Has Eaton made any improvements on them making it worthwhile to try one again.
    I have a Lipe clutch in my parts room that I can use but I’m not sure my old knee would like it.
    I’m open any comments.
  3. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,115
    Jul 12, 2017
    Solo are Ok as long as you dont care about longevity. They never outlast a manual adjust and never make it to worn out mark. If you dont want to adjust and hate down time, this may be for you.
    If my bet is on longevity and best bang, it's easy pedal-manual adjust all week long and twice on Sunday, as long as you take the time to adjust it correctly when it needs it.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    They never outlast a manual adjust and never make it to worn out mark <--- well said!
    bigguns Thanks this.
  5. AModelCat
    161,536
    Now do solo clutches not last because everyone floats and seize due to lack of use? Or are they just crap?
    bigguns and Bean Jr. Thank this.
  6. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Ok. No Solo. 7 spring vs 9 spring?
  7. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    My understanding with the Solo is that resetting them from time helps to keep them free and working.
    Human nature. If it isn’t a problem there’s no need to check it.
  8. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    solo is crap
  9. Goodysnap
    3,748
    9,115
    Jul 12, 2017
    I suppose I would lean toward the 9. More springs and more dampening ability? The 9 spring according to Eaton is a HD version. Never really payed close attention to either version.
    IMO there are 2 things that progress a disc to crack and spit dampening springs.
    1. Extended Idling, PTO time/ rapid and repetitive rpm changes under load.
    2. Repetitive harsh engagement or what I like to call light foot.
    I can tell you this, some come out looking good still and others are obliterated. Someone's doing something wrong........and it's not the clutch.
    bigguns and spsauerland Thank this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,525
    6,586
    Aug 26, 2014
    Someone else brought this up. Do not remember whom.
    If you use a clutch rated for your engine it should be enough. The heavier the clutch the more pedal pressure is required to push it.
    My left knee might be better if I did not always buy the heaviest clutch that fit in the hole.
    bigguns, Bean Jr., SAR and 1 other person Thank this.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    My rule of thumb anymore is manual linkage, manual adjust clutch. Hydraulic controlled clutch gets a solo. I put the 2050 in all, new not reman. Eaton was saying "over clutching" or using 2050 in all was not a good idea, but the HD ECA clutch only has two, the 1850 and 2250.
    bigguns, Bean Jr. and SAR Thank this.
