Clutch costs
Discussion in 'Kenworth Forum' started by Thunderroad, Nov 7, 2012.
average is $1500-$1800, but depends on where you go. If you shop you can do better.
Thunderroad Thanks this. -
Assuming you meant 1500.00 It's a little less than I guessed. Cute girl cute cat Thanks
Yeah, sorry, one too many zeros. Price can vary a bit depending on if it needs an input shaft or cross shafts, bushings and release yoke and if you choose a new or rebuilt clutch assy. Thanks, that's one of my brats and her new kitty.
Clutch around $550-$750 Swapping out should be around another $800
I just had my 09 Kw T-800 done. $1820.00 total.
Don't be cheap, do the engine mounts and input shaft as well. Cross shaft should be looked at and probably replaced. Also take a look at the rear engine seal.
Another vote for doing rear main seal. It costs a whole heap less to do when the clutch and gearbox are out and it is actually a pretty cheap part.
Got it all done $2200
clutch and rear seal 1300.00.have good mechanic who does everything on my truck
