clutch fan problems
Discussion in 'Freightliner Forum' started by truckerbangin, Feb 4, 2015.
  1. truckerbangin
    truckerbangin Light Load Member
    262
    44
    Jan 22, 2013
    Good day all i my engine fan is on all the time the solenoid works fine but the fan clutch wont disengage. is there any other ways to test the fan clutch to see if its bad?
    Shadowhawxzzz Thanks this.
  3. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    140
    Apr 23, 2013
    Do you hear air coming out of the hub with the key on? If so, the seal inside is busted. You can get a rebuild kit for about $100. I tried to do mine but couldn't get it apart, ended up buying a new one for $750.
  4. 201
    201 Road Train Member
    12,061
    24,626
    Apr 16, 2014
    high plains colorado
    Hi truckerbang, with the engine off( duh) the fan should spin freely. Could be a seized bearing in the hub.
  5. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    did you check to see if you have a manual switch for the fan. it may be on or stuck on. if that's not it do what semi retired said. the clutch should spin freely with the engine off. if not the bearing could be froze.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I wonder what the definition of solenoid works fine is? I also wonder what year everyone's trucks are answering and asking questions? Assuming his is the same as ours could be incorrect. Manufactures change standard equipment suppliers occasionally and companies can order nonstandard equipment. What brand is the fan clutch, Hayden, Horton, Kysor, Rockford, other? It sounds like this clutch is controlled by air and the air by electric solenoids. Some air controlled clutches use air to disengage them and others are air engaged. Regardless of all of that the fan clutch should engage or disengage with air application, of course engine off, shop air or truck air. Then you know if you have a clutch or a control system problem.
    tommygun58 and Rideandrepair Thank this.
  7. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Volvo has never built a d12 with a fan clutch that uses air to engage it. So, either the solenoid is not sending air, the orings in the clutch are shot leaking air and I guess it's possible that there could be a blockage in the line.
  8. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I'm a bit confused.
    Where did you get Volvo and D12 from any of the conversations above?
    I'd like to add for the OP.
    I had a similar problem with mine. I have a C15 in my Columbia. My fan was staying on all the time as well. How ever,.. when I turned on the A/C,.. the fan magically returned to normal,.. only turning on when it was supposed to. Turn the A/C off and the fan would come on soon after and stay stuck on. Turned out to be the A/C high pressure switch. Replaced and the fan now works as it should.
    Hurst
  9. simon999
    simon999 Light Load Member
    240
    95
    Feb 6, 2014
    You need special tools to press seals.
  10. Helowrenchturn2
    484
    140
    Apr 23, 2013
    My bad. Got this confused with another thread I had been reading. Sorry
  11. Helowrenchturn2
    484
    140
    Apr 23, 2013
    Bearings yes, seals no. And the bearings can be put in without a press but it's a pain in the rump. I'm referring to the horton druvaster series which is on d12's but, again, I was confused about the thread I posted in. Here's a video on rebuilding a drive master. https://m.youtube.com/watch?v=fuDpQHlExs4
