Clutch fan
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by lwlevens, Mar 10, 2018.
  1. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Did all the Detroit 60 engines come with clutch fans I'm looking at a 99 Sterling triaxle that doesn't have a clutch fan unless someone changed it out. Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,706
    8,987
    Jul 12, 2017
    Fan clutch is truck manufacturer installed. Not an engine component. So as you already noticed, it depends on the truck, not the engine. If it has a fixed fan, shouldn't be that big of deal to put a clutch in if that is what you want.
  4. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Sure it isn't a viscous fan clutch?
  5. lwlevens
    623
    427
    Feb 9, 2018
    Ok thanks just thought they came with clutch fans. Think it's a mechanical fan though .Truck runs cool so i guess it doesn't matter.
  6. kemosabi49
    10,514
    44,863
    Jan 13, 2013
    SW Arkansas
    Engine fans use horsepower. Horsepower used = fuel used. You don't need it running all of the time. As @spsauerland said it could be a viscous fan clutch. You should find out.
  7. lwlevens
    623
    427
    Feb 9, 2018
    Yeah I will I'll ask the owner.
  8. lwlevens
    623
    427
    Feb 9, 2018
    Just wondering how much extra fuel and hp will I use with a mechanical fan then using a clutch fan?
  9. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    35-45 HP the fan will use in most application's. Noise , and low mpg will be the results of fixed fan.
  10. lwlevens
    623
    427
    Feb 9, 2018
    Sorry if I keep asking stupid questions this is all new to me. A viscous fan clutch uses fluid alone and NOT air right? So I can just install an viscous fan clutch instead of trying to trouble shoot why my clutch fan is running all the time.I can buy a used viscous fan clutch for 200.00.:confused:
  11. AModelCat
    156,894
    In the automotive world they are stand alone items (no external connections). I deal with a lot of bigger Horton viscous clutches and they are triggered electronically. You're better off with air IMO.
    Goodysnap Thanks this.
