Clutch is killing my knee !
Discussion in 'Questions From New Drivers' started by dennisroc, Sep 20, 2019.
Thread Status:
Not open for further replies.
  1. dennisroc
    dennisroc Road Train Member
    1,753
    1,257
    Oct 9, 2013
    Anjung-Ri, South Korea
    First 2 weeks of school over and today started backing on the range.
    Other students were complaining about their knees hurting but I actually had to stop and put the shifter into neutral to rest my knee during my parallel parking , I had to let that clutch out ,so much pain.
    Can anyone tell me how to stop this severe pain ?
    Thanks
    Hegemeister Thanks this.
  3. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    Only use the clutch to start going from a stop. Other then that or heavy traffic and backing you dont ever need to use the clutch
    Texas_hwy_287, Lepton1 and Dino soar Thank this.
  4. Chinatown
    Chinatown Road Train Member
    76,985
    179,717
    Aug 28, 2011
    Henderson, NV & Orient
    Tylenol for arthritis tablets. 650 mg./take two
    Hang in there until you graduate and get with a company that uses automatics.
  5. snowwy
    snowwy Road Train Member
    20,591
    13,311
    Jul 6, 2009
    They've probably got a old stiff clutch. Or one of them heavy clutches.
    I won't swear for all trucks but my replacement options were 1800 lbs and 2200 lbs. 2200 being a stiffer clutch.
    I could see 2200 being used for heavy haul but for standard 80k. 1800 is just perfect. And the knees like it too.
    Texas_hwy_287 Thanks this.
  6. CraigInReston
    CraigInReston Light Load Member
    137
    134
    Apr 6, 2017
    Most driving schools require using the clutch, or double-clutching. Just bare with it until you pass the road test, then you can drive like the rest of us. I know it sucks... it will be over soon enough.
    Lepton1 Thanks this.
  7. Espressolane
    18,278
    113,801
    Try adjusting the seat for both ride height and clutch pedal movement distance.
    If the clutch is good and adjusted correctly, you should only need to move it about 2 inches to break torque.
  8. tscottme
    tscottme Road Train Member
    Schools and most DMV examiners do not want to see you floating gears. They expect you to double-clutch. While they are some exceptions to the above, nobody's ever failed a DMV test because the double-clutch.
  9. tscottme
    After you clutch a couple of thousand times, it will just be *one* of the pains you feel every day.
  10. Dave_in_AZ
    414,605
    I tore my ACL in my left knee 20 years ago.
    Drove a 359 eleven yard concrete mixer for 3 years, various local, can still jump out of trailers.
    This pain. In your knee. Can you describe it ?
    Texas_hwy_287 and FlaSwampRat Thank this.
  11. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    i use to teach the adams family song when i was a school instructor. you sing the song. and go clutch fuel clutch
  • Thread Status:
