Clutch issue not sure?
Discussion in 'Peterbilt Forum' started by Oldironfan, Jun 26, 2018.
  1. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Was just driving in SD on I 29 going north at 74mph in cruise, than came up a slight hill very slight. Than engine revved up to 2200 or enough to show red oversees warning. I am light loaded with a 579 mx13, and 13 speed eaton? 410,000 miles on 15 year truck. It's not mine.
  3. bigmotor1212
    bigmotor1212 Light Load Member
    256
    363
    Dec 20, 2014
    Had to be the clutch or you broke traction.
    Bean Jr. Thanks this.
  4. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Do you have freeplay in the clutch pedal?
  5. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Clutch. It either needs adjusted or replaced.
    Do you have any free play in the pedal at all?
    SAR and Bean Jr. Thank this.
  6. nikmirbre
    nikmirbre Road Train Member
    5,441
    9,869
    Jul 27, 2011
    High Point NC
    I just went through same problem..... it only happens on hills... loaded or empty. More prevalent when loaded. I had my clutch replaced over a year ago. Stopped and had it adjusted, problem went away.
    Then I about broke my neck leaving the shop with the clutch adjustment..... lol
  7. Oldironfan
    5,777
    5,543
    May 22, 2017
    The clutch grabs near the very top of petal. Was told can't adjust much as it's hydrolic? I did not loose traction on dry pavement cruising constant 74mph. I'm guessing idiots drive this truck before I did. And clutch needs work.
  8. Goodysnap
    Goodysnap Road Train Member
    3,724
    9,054
    Jul 12, 2017
    It can be adjusted. There is no way to feel the freeplay with the hydraulic actuator. First giveaway is the clutch brake will be gone from the bottom of pedal travel. Having issues getting into gear?. Get In the shop and get it adjusted pronto.
    BoxCarKidd and Oldironfan Thank this.
  9. Oldironfan
    5,777
    5,543
    May 22, 2017
    I do not think my carrier mechanic know how to do that. Nor do I. May need Peterbilt to do it. But that's ok guess I an wait.
  10. Goodysnap
    3,724
    9,054
    Jul 12, 2017
    The clutch adjustment is nothing special and is the same as it has been on every eaton clutch for years. Set the 1/2" gap bearing to brake and go. No linkage to adjust with the hydraulic actuator. If it's a solo you may have deeper issues than adjustment however, but the wear tab should show closer to replace if it slipping and is a solo which means it's time to replace.
    AModelCat Thanks this.
  11. Oldironfan
    5,777
    5,543
    May 22, 2017
    I have notice splitting gears down it does not catch very good need to be at perfect rpm.
