Clutch Problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by terrylamar, Dec 26, 2010.
  1. terrylamar
    terrylamar Road Train Member
    1,023
    368
    Oct 8, 2006
    Austin, TX
    I have a Eaton Fuller RTOC - 16909A which has been converted to a 13 Speed. I am having difficulty getting it to come out of or to go into some gears. This seems to be random. My clutch brake isn't working either. I have to turn the engine off to get it to go into first. I recently had the clutch adjusted after I noticed it slipping. Is it possible that it was adjusted too tightly and the clutch isn't releasing properly. Or what else could the problem be?
  3. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    How much free play do you have in the pedal?
  4. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    1.5" ......
  5. DL550CAT
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Did you mean it was slipping before you had it adjusted or after?
  6. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    all problems you describe now are usually related with shaft brake and clutch ajustment. Try to reajust. I had the similar problem, but a bit different way... I had to depress clutch pedal, wait 5 sec and engage gear.
  7. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    It began slipping badly and the clutch had no freeplay at all. I had it adjusted and everything seemed to be OK, just took a couple of days to get used to it after the adjustment.
    Now it is not slipping, but the clutch brake is not working and is harder to put into or out off gear. I can bump the fuel pedal and it will slide into gear, nothing like it was before.
    I have, since, installed the Bully Dog, but I drive 57 MPH everywhere I go and have not over torque the engine at all.
  8. DL550CAT
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    If you have a 1.5" of free play and the clutch is slipping sounds like you need a clutch.
  9. terrylamar
    1,023
    368
    Oct 8, 2006
    Austin, TX
    No! It is not slipping! It was and was adjusted. Now, a month after it was adjusted, it is hard to put into some gears and the clutch brake is not working. I think when they adjusted it it had more than 1.5."
  10. DL550CAT
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    It might have had a little grease on the clutch brake. If thats the case end of clutch brake or it could be just wore out. It can be changed without pulling the trans. Another thing you might have some linkage worn. I would suggest you take it to a good driveline shop not a Petro, TA or dealer but a actual clutch shop. They seem to have better rates and know exactly what to look for.
  11. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    try to reduse clutch play to 0.5"''
