So I have 99 international 10 gears . I had to put a new clutch in it a year ago and now I just started to hear a grinding noise After its in gear and I pull off. This also happens in reverse. Goes in to all the gears fine it pulls off fine its just makes this grinding noise from time to time but it seems to be getting load and more frequent. Just wondering if anyone had this problem or could give my some ideas on what to do the clutch is only a year old.
clutch problems
Discussion in 'Ask An Owner Operator' started by Cusmar22, Feb 8, 2015.
Adjust it ?
Ck the ride hight of rear end, if air valve is worn its jacking up sup. then slow to let it back down to correct ride hight an making noise while its riding too hi?
You will know when the clutch has to go, as in the truck wont go.
Is it grinding while the clutch is pressed in or fully released? Is the grinding like a transmission grind or a rear end grind?
When the clutch is releasing when im almost off the clutch. But I can feel the grinding on the clutch pedal .
I had it adjust like two months ago but im going to take it to my mechanic to see if it still needs to be adjusted.
Yes I know i'm just wondering if the is a small problem or a major one.
Throwout bearing??
