Clutch, When at a red light do you wait in neutral or in gear?
Discussion in 'Questions From New Drivers' started by Kfrancistrucking, Dec 20, 2018.
  1. Kfrancistrucking
    Kfrancistrucking Bobtail Member
  3. DualsThatTouch
    DualsThatTouch Bobtail Member
    27
    37
    Dec 9, 2018
    Illinois
    In gear, clutch in, foot on brake.
    WVRose, snowlauncher, skellr and 5 others Thank this.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Don’t be that guy that has to put it in gear after the light turned green and hold everyone else up.
    Then I miss the greenlight because you didn’t have any common courtesy for the people behind you.
  5. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    We have a turn light in Portland that alternates. Unless you know you’re next. You’ll be holding that clutch for a very very long time.
    It allows traffic to flow from all 4 directions twice, before giving the person in the left turn lane a green.
    And it’s on a grade of course.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Depends, if i know it's a slow light I'll sit in neutral, or if I'm behind a few 4 wheelers it always takes them way longer than it should to get moving.
    Lepton1, JReding, Nothereoften and 3 others Thank this.
  7. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    But I had to check my phone, and I can't do two things at once.:rolleyes:
  8. Numb
    Numb Crusty Curmudgeon
    4,072
    9,369
    Jan 30, 2012
    Charlotte, N.Carolina
    in gear.
    Rideandrepair Thanks this.
  9. buddyd157
    buddyd157 Road Train Member
    13,564
    34,840
    May 25, 2017
    under a shade tree
    i usually pull the brakes shut the engine (no idle policy) and eat my lunch, maybe read the newspaper.
    then when the light turns green, i re-start my truck, and put the trans in LL..
    by the time i am thru, everyone else has to stop....
    kinda depends, at most lights i have to stop at, i can see the changes of the lights.
    sometimes, if they are long lights, i put it into neutral, if they are quick lights, i leave it in gear.
    but on my route, i am lucky, that i am on main roads/streets, and late at night, the streets i am on, the lights stay green nearly forever.
    it's only when some driver, in front of me, stops his truck, pulls his brakes, shuts his engine off, and eats his lunch and reads the newspapers, that i have to hope i don;t get caught at another turn of the lights.
    Lepton1, JReding, Oxbow and 3 others Thank this.
  10. 201
    201 Road Train Member
    12,330
    25,214
    Apr 16, 2014
    high plains colorado
    In gear. Never know when you may have to move in a hurry. Many of the trucks I drove had worn clutch brakes, so if in neutral, you'd have to grind to get into 1st, so before I stopped rolling, I'd put it in gear. The Mack R model I drove had a stiff clutch, which is why I rarely used it. It took both feet to keep it on the floor at a light.
  11. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I did a lot of city driving and on surface streets. With a super tanker in town (gross110,000lbs) you try to time the lights if you can. A lot of checking the opposite cross walk sign and making sure the light is not stale. If I had to stop it depended on that light if I went into neutral or not. Also it made a big difference if the clutch brake worked or not.
