Co-Phase tuning problem
Discussion in 'CB Radio Forum' started by Fudz073, Apr 8, 2012.
  1. Fudz073
    Fudz073 Bobtail Member
    18
    Apr 4, 2012
    Pennsylvania
    I'm currently installing co-phased antenna's onto my jeep (2 4' firestik II antennas) . I'm using a simple steel tube mounted on the roof to attach the antennas to. Before I tune both antennas in co-phase, I'm tuning either side of the jeep individually to make sure I'm @ a good SWR. The drivers side of the jeep is tuned to a 1:1 , the passenger side is jumping off the charts. For some reason, I cannot get a good SWR reading for the passenger side. I've interchanged all the connectors and mounts, tried several different grounding options and use the same antenna for each side while I'm testing for the individual SWR.
    I understand that both antennas need to be tuned together when in co-phase. The reason why i'm testing both of the antenna's individually is to make sure that both antennas are properly grounded.
    Does anyone have any ideas of why I cannot get a good SWR reading for the passenger side of my jeep.
    Appreciate the help!
  3. cuzzin it
    cuzzin it Road Train Member
    3,639
    11,564
    Jan 19, 2008
    Berea, KY
    Why do you want to co-phase on a 4 wheeler ? if it's not that important i'd go with one, you are not likely to do any better with two....
  4. Fudz073
    18
    Apr 4, 2012
    Pennsylvania
    Might have to. This is driving me nuts. I really just want to know why I can't get a good ground on the other antenna:biggrin_25510:
  5. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
    stick one 102 inch steel whip from radio shack on that jeep. best antenna dollar for dollar you can spend, and that will not be too much. the steel antenna will have twice the gain of one of those cheap firestiks.
  6. IDIeselman
    IDIeselman Light Load Member
    173
    59
    Feb 23, 2011
    Ludington on the Lake
    Here's a little something I picked up from the worldwidedxforum . 2 antennas for the cb will only really be beneficial if you can get them spaced at least a 1/4 wave apart (approx 9ft) less than that the benefit is seriously minimised and any gain would be offset by radiation pattern distortion, you'd be far better off using one in a central location (ideally roof mounted) for an omni directional radiation pattern, the other problem you would encounter with 2 antennas is co phasing them,as the antennas would be parallel to each other you would have to use a 75 ohm co phase harness to get them matched, using a dummy load on one as you match the other and vice versa. not for the feint hearted if you ain't sure how to do it. Diesel rig drivers can run dual antennas. But that's because the antennas are 9 ft apart! They also transmit bi-directionally. It works for them. You will see better performance with only one of your antennas mounted to your tire rack or rear bumper, cowl mounted antennas seem to perform just as well. With your jeep you do have some hurdles to overcome as there really is not a "good" mounting place.
  7. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I don't understand why anyone needs gain for a mobile radio anyway. You're limited to line of sight except when the band is open, and 4 watts will get you to the radio horizon easily and be enough to take advantage of ionospheric propagation (skip) when it's available.
  8. cuzzin it
    3,639
    11,564
    Jan 19, 2008
    Berea, KY
    Yes i'm anxious to know why as well. meanwhile one should do it just fine.
  9. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    If you haven't grounded BOTH ends of the steel tube (ground braid from each end of the tube to the vehicle body), then it may be causing phasing problems.
    cuzzin it Thanks this.
  10. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Did you make your own coax harness, or did you use one that was made for the array?
  11. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
