Wanting to add mirror mounted brackets and new antennas, stumped on the best way to run the coax back into the cab. 03 Century.
Coax routing options
Discussion in 'CB Radio Forum' started by Mrfasttrack, Sep 12, 2016.
I'd buy a socket set and start taking things apart. Best to follow factory cable routing to avoid pinching cable in door or window.
It's a 03? Trucks long past being New...Get a drill and a 1/2" bit and drill a hole as close to the mirror as possible...run your coax in, then get a tube of silicon and plug the hole up...Problem solved...
rabbiporkchop Thanks this. -
Don't want to drill. Run it into the engine compartment and thru the firewall somewhere. You can add additional protection to the exposed part.
Personally i would use rubber grommet over silicone.
Silicone is good for water infiltration.rabbiporkchop Thanks this. -
There's usually a rubber grommet in the firewall that you can puncture with a knife and slide a cable through
Ougigoug Thanks this. -
Actually I was just being sarcastic...
although I guess it would work.
