cobra 25 s/rf meter light bulb
Discussion in 'CB Radio Forum' started by Leeworthy, Sep 18, 2013.
  1. Leeworthy
    Leeworthy Bobtail Member
    49
    12
    Jul 8, 2012
    Belleville, Ontario
    Hey ya'll. Anyone know how many watts the bulb needs to be to replace on the cobra 25 that lights up the s/rf meter. I pulled one out the other day that was burnt out. Found an LED that was in one of my garden lights wired it in, and then it burnt out rather quickly, assuming it couldn't handle the voltage going to it. Anyone know what watt I need to replace it with?
  3. Ridgeline
    22,164
    113,688
    The LED couldn't handle the current that was going through it, not the voltage. You have to put a resister in line with the LED to limit the current. Try a 560 ohm resister.
    Those bulbs are hard to find.
  4. 6string
    6string Bobtail Member
    49
    13
    Mar 24, 2013
    no thier not you can order it online or go to radio shack and get a 12v lightbulb part its not much
    I know cuz ive replace mine before i bought mine from radioshack
    otherwise you have to run a 3mm-5mm LED bulb to the radio plus a 470 ohm resistor 1/2 watt no lower
    if you skimp on the resistor it will blow everythime
  5. Ridgeline
    22,164
    113,688
    Yes you are right, rs has them, they didn't when I went there but they also have 3d printers now too.
    by the way you don't need a 1/2 watt resistor, 1/8 watt will work just as well.
  6. BTShepp
    BTShepp Blue Demon
    373
    215
    Oct 31, 2015
    Chicago, IL
    Other then personal preference, is it advantageous to change stock bulbs to LEDs?
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    Nope it's super easy to change the bulbs to LED's. Biggest thing you need to know is the polarity. LEDs don't work on reverse polarity like typical incandescent bulbs do. Most times the meter lamp bulb wires will be the same color. You'll need to use a cheap multimeter to determine which wire is positive and which is negative.
    And you can get the LEDs on ebay. Easy to find.
  8. Lowboy456
    Lowboy456 Light Load Member
    278
    127
    Mar 14, 2017
    If I take a working light out of a Cobra 25 and put it in a Cobra 29 will it need the resistor?
    Theres not one installed currently
    in the 25.
  9. Lowboy456
    278
    127
    Mar 14, 2017
    Turns out my Cobra 25 had a blue Led in it. It had a resistor covered in heat shrink which on that radio reduced voltage from 11.5 to 3.1v
    The cobra 29 read 12 .5 v on the meter light circuit before the resistor and I assume it read 4.1 after the resistor. It worked fine in the 29.
    Looking at the radio from back to front the light plugs into the meter down on the left side. The light was inside a soft rubber square plug that fits so nicely with 2 red wires going through it, it didnt look like it could be popped out. This thread helped me to solve my issue and was literally the only thing I found that had just the right info.
