Cobra 29 classic bad srf/swr/cal switch
Discussion in 'CB Radio Forum' started by Krimbo, Mar 4, 2018.
  1. Krimbo
    Krimbo Bobtail Member
    7
    I have searched everywhere for info about this switch with zero results online.The switch is completely worn out and just flops around. I can't find any info about how to replace it or where to buy it but would be happy just bypassing it if possible if I knew which wires to cut and connect.
  3. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
    Krimbo Thanks this.
  4. Ridgeline
    22,635
    120,562
    Ken won't have it, I can't see it wearing out but hell anything is possible.
    OK it is a three position double pole slide switch, I most likely have 20 of them somewhere (maybe in storage with all the other crap).
    There are a couple places to get it, one is Mouser/Digikey - they are about $2 each.
    I don't remember if the switch is soldered to a board or not but Mouser has one that may work - 642-MHS233K is their part number. They only have 880 in stock so ...
    Another place is Cobra as a replacement part.
    and a third is to find someone who scraps out radios and has a few from older radios.
    Krimbo Thanks this.
  5. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    That is really strange for that switch to be worn out. It has 2 little screws holding it to the frame behind the face plate. Have you checked to make sure those screws are tight?
  6. Krimbo
    7
    The problem is that the switch won't stay in one position and it's screwing up normal talking operation.There is no tension to keep it from moving around. I think I'm just gonna get a wiring diagram and bypass it.
  7. Ridgeline
    22,635
    120,562
    But it shouldn't screw up anything, it is there just for the meter on transmit.
  8. Krimbo
    7
    It wouldn't stop transmission if the switch dropped into cal or swr mode?
  9. Ridgeline
    22,635
    120,562
    no, just make the meter act weird.
    I would just jam a piece of paper or something into the slot with it I think all the way up and leave it there until you get around to getting it fixed.
  10. Krimbo
    7
    Ok thanks. It's just an old radio I got for free anyway.
