Cobra 29 LX won't calibrate SWR!!
Discussion in 'CB Radio Forum' started by canadianAWFB, Mar 13, 2017.
  1. canadianAWFB
    canadianAWFB Bobtail Member
    I have installed a cobra 29 LX in my 1991 f250 with a fire stick 4' antenna with 18' of coax. I tried to tune the SWR on the radios built in meter and I found that every channel had 1.3 SWR. So I thought that was weird due to that I just installed the radio. I then unscrewed the tuneable tip of the antenna and got all the same readings. There are no warning lights or anything. I have been playing with the height of the adjustment screw for a while and still have had no luck with the meter changing the SWR. Anyone have any suggestions what it might be? I have gone over the coax and have found no resistance. HELP!!
  3. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    I wouldn't trust the radios built in swr meter I have rarely seen one give a accurate reading, you should invest in a decent swr meter and use that to check and set the swr. I have a Bearcat 980 and it gives a reading of 1.0 no matter what truck the radio is in ( semi or pickup ) or what antenna Im using.
    slim6596 Thanks this.
  4. canadianAWFB
