Cobra 29ltd classic questions
Discussion in 'CB Radio Forum' started by Dark_Majesty_06, Sep 10, 2009.
  1. Dark_Majesty_06
    Dark_Majesty_06 Road Train Member
    1,072
    332
    Jun 15, 2009
    Poplar bluff, mo
    I was recently given a cobra 29 from my father in law to replace my uniden 78. My question is... On my prostar its set up dual mount with stock wire. I put dual 1000 watt everyday 29.99 at a truckstop ant. My drivers side is about 1/2 inch short cause of the adapter.
    My range is kinda sucky.. Bout 2 miles and my channel 40 swr on radio meter is right at the crack in the top red line with the arrow at the end of the worf cal. My channel 1 although.. Is only up to the "c" in "cal". Is this cause by mis lenght.. Or stock wire.. Or are both contributing factors?
  3. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    Sounds like bad coax. The slightly shorter antenna should not have this affect.
  4. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    I'd agree... an inch or two won't be a problem at CB frequencies... only when the lenght mismatch gets to be around 1/4 wavelength. Bad coax, loose connections would be my guess as well.
  5. FriedTater
    FriedTater Keeper of The Snakes
    2,202
    887
    Mar 25, 2009
    United State of Texas
    Check the connections make sure their tight on the mount studs.(Use Pliers) Also verify it is a true Co-Phase Coax set up.
  6. Dark_Majesty_06
    1,072
    332
    Jun 15, 2009
    Poplar bluff, mo
    10-4. I noticed my antenna wasn't quite secured. But even after I tightened that up.. My sw was still the same and range. Ill check my coax. If nothing else.. Ill have a cb shop do everything up right for me.. New coax. New antennas and a peak, tune and connex board too.
  7. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    Be careful letting a shop set you up...some of them don't have a clue to what their doing.....they just want your money.
    Also don't rely on the radio's built in SWR meter, they are not very good. get you an external meter, like a $50 one from Radio Shack.
  8. Dark_Majesty_06
    1,072
    332
    Jun 15, 2009
    Poplar bluff, mo
    Okay.. That's what dad told me. Lots of dummies out there. Let me ask u know..which radio would u guys prefer to have if u were gonna modify it? The cobra 29 classic or the uniden pc 78?
  9. Turbo-T
    1,953
    708
    May 31, 2009
    Either one is a good radio and basically the same. Cobra just has the bigger name for some reason, but they're not really any better than a Uniden. Heck for the longest time the 29's all used Uniden boards.
    But then again if I had to pick a back lit model I'd go with the 78 Elite over the 29 Nightwatch ANY day of the week. Because the 29 NW is run by 1 LED/xformer and once it blows out, it's easier to replace the radio. The 78 Elite uses multiple LEDs so if one happens to go out the whole face doesn't go dark.
  10. Dark_Majesty_06
    1,072
    332
    Jun 15, 2009
    Poplar bluff, mo
    Wounderful. When I first started truckin a few months ago.. I didn't notice there were two cb hook ups on my prostars mirrors.. And only one antenna.. So I burned something up on my 78.. But I'm actually at a truck stop in albuquerque,nm that has a cb shop.. So I'm tryin to get a deal worked up.. Where I trade my 29, then he fixes my uniden, peaks and tunes and gives me a rk56 mic.
