Cobra 29lx questions?
Discussion in 'CB Radio Forum' started by Steveo412, Nov 12, 2014.
  1. Steveo412
    Steveo412 Light Load Member
    53
    Mar 29, 2014
    Holiday,FL
    I have the radio its self mounted to plastic. Should the radio body be grounded to the truck? Running a wilson 1000 roof mount with a RoadKing RK564PCH Chrome 4-Pin Dynamic Noise Canceling CB Microphone with Flex Cord. I can hear people well but every says im real quiet on the mic if at all. do I need a ground ran off the antenna. Or ground the radio off the mounting holes. Kinda lost on what I should do or test. I had about 4 to 5ft of extra cable from antenna that I ran the length of the dash in stead of coiling up the excess coax. Any direction would be nice. Thanks.
  3. mike5511
    mike5511 Road Train Member
    3,154
    1,544
    May 15, 2011
    NW Arkansas
    It wouldn't hurt to ground the radio to the truck. But your problem sounds like you need to turn the mic gain up, or you have a bad mic. Is your SWR good? The antenna should be well grounded already if it is a roof mount....unless you have a plastic roof. Even a mag mount should be good as far as a ground is concerned. If you haven't already, you should make sure you have a good SWR. Turn your mic gain all the way up. If you are not loud enough then you should switch mics and try again. Get somebody you know to help you test so you can rely on their feed back.
  4. Steveo412
    53
    Mar 29, 2014
    Holiday,FL
    Thanks mike im going to do some trouble shooting tonight.
  5. Steveo412
    53
    Mar 29, 2014
    Holiday,FL
    I bought it all new with a roadking 56 and from what im reading they have problems with the newer models. Im going to take it apart and make sure all the leads are secure and check continuity. Could
  6. Steveo412
    53
    Mar 29, 2014
    Holiday,FL
    My swr is about 1.1
  7. Steveo412
    53
    Mar 29, 2014
    Holiday,FL
    Ok its the roadking 56 mic, the stock cobra works great. It sucks because im just figuring it out that its bad. I bought it new in april. Feel like I screwed my self on this one lol.
  8. Powder Joints
    7,877
    8,175
    Sep 25, 2007
    Rosamond, SoCal
    I have been using RK56 mics for years never had a problem, except the switch wears out in about a year. I habe recently switched over the astictic noise canceling mics Though I would try them as they are half the price of a RK56. So far they work well.
  9. KAK
    KAK Medium Load Member
    518
    2,073
    Feb 10, 2012
    Ne
    Ranger SRA 198 is the best by far of the "new mics" . Can be had for $25 or a lil less on the bay
  10. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    The new rk56 are not what they used to be but remember your stock mic will be louder its not a noise cancelling mic some ppl don't realize you need to put that Boise cancelling mic touching your lip and speak loudly into it that's why they have a lip guard on them
    handlebar Thanks this.
  11. Steveo412
    53
    Mar 29, 2014
    Holiday,FL
    Purpleprime I was kinda wondering about that. I wish there was a way to get rid of the noise cancelling part.
