Cobra S500 external speaker: talkback...
Discussion in 'CB Radio Forum' started by volvo244t, Apr 28, 2014.
  1. volvo244t
    volvo244t Road Train Member
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    Is there anything that can be done to increase the talkback in this thing? Out of the box, turned on and maxed out...it's approximately useless, not terribly unlike on the stock Cobra radios that have talkback built-in. My 29LX has it, and I had it increased so it's actually usable... but I'm running a 148 now.
    The noise reduction button is wonderful, though.
  3. MsJamie
    MsJamie Road Train Member
    I first read the headline as:
    [h=2]Cobra $500 external speaker: talkback...[/h]
  4. BigBearNY
    BigBearNY Light Load Member
    160
    37
    Mar 14, 2014
    Can you solder? If so any number of inexpensive mini amp kits can be put right insid the speaker... I believe Radio Shack still sells them or thy can definitely be had on EBay. Only issue is that you will have to run a power lead to the speaker or add a battery holder to power the amp. Kits are usually based on a small amp IC with a few other components. They are often sold as educational kits. I used this solution on a boat many years ago. Note... This will add volume to any sound going to the speaker. I have seen kits with and without adjustable volume.
  5. volvo244t
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    The issue with that is that the normal audio is plenty loud, so amplifying everything won't really help... I know that in the Cora radios that have but in talkback, there are two resistors that you can jump across and considerably increase the talkback...so I am mainly wondering if the circuitry in the speaker is similar.
  6. BigBearNY
    160
    37
    Mar 14, 2014
    Maybe you don't really understand what talkback is.... You are simply hearing yourself as you sound going out on thew air. The ONLY increasemin talckback would be volume. Placing an amp in the speaker WOULD not effect the audio that goes out over the air. It would only allow you to hear yourself louder in the speaker.
    Possibly you have another issue you were not quite clear on?
    Once you install the resistor you have talkback... if you can't get enough volume on the speaker, the only way I see is to replace the speaker with an amplified speaker or alternately add an amplifier to the existing speaker....
  7. volvo244t
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    Sorry, I was plenty tired when I wrote that post.
    What I meant was that if I amplify the speaker, both the receive audio and the talkback will be louder, but the receive audio is plenty loud already, so I don't want to increase that - just the talkback.
  8. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Not sure there's anything you can do with that speaker to make the talkback louder...Unless you want to try and ad some kind of amplifier board...I had one of those Cobra speakers once, and was also less than happy with the talkback...
    Not sure...But I know the RF Limited Xtream 2018 Mic has a talkback adjustment on the back of it, using one of these Mic's "Might" help the talkback out to be a little louder...not sure tho, but if your in the market for a new mic anyway, it maybe worth looking into.
  9. volvo244t
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    I particularly like my Ranger SRA-198. The only mic I'm really looking to get right now is a CR-577.
    I may just buy a second speaker to tear apart and see if I can do anything with it. Or, if worse comes to worst, just solder a small resistor in-line with a potentiometer between the ext/pa jacks to get talkback in the radio and have it variable.
    If only I could get my hands on a schematic...
  10. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    http://www.cbtricks.com/radios/cobra/index.htm
  11. Ridgeline
    22,312
    115,449
    Actually that's not right. The talkback feature is the audio that is going to the final stages of the rf section which modulates the carrier. If you want to hear yourself properlyon the air, then it is a bit more complicated than picking up the audio before the finals.
    OK to the OP, the problem is that you can't do much with it. Many CBs ground the PA jack output and I am thinking that the 148 is one that does just that in order to prevent the PA speakers picking up RF. SO... adding an amp wouldn't work but would is a simple mod to add talkback to the radio and the speaker would. Pretty much the red lead acts like a mini antenna with some radios and picks up RF and it goes through the speaker.
    Just like many other marketed things, people don't think when they design these things to work, they just wanted them to sell. By the way, did you get an instruction sheet with the speaker? I never did and was told they don't have them but who knows with Cobra.
