Code 259 Cummins isx
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RSB34, Nov 1, 2018.
  1. RSB34
    RSB34 Light Load Member
    277
    198
    Feb 9, 2013
    ny.
    ive been having boost issues won’t boost more than 25psi. Today the stop engine light came on. So I turned the key hit the dionostic switch. It flashes twice the five then nine and the repeats itself. So I’m guessing that’s a code 259 from what I read it the fuel shut off celinoid. It has been taking about 10 seconds to shut off once the key is off. Will this derate the engine? Can I drive it about 70 miles home to fix it? Or am I reading it all wrong? It’s a 99 570 600hp
    Thanks
  3. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    You are correct. It is the fuel shut down solenoid. DYI job if you are so inclined. ! hour labor at a shop.
  4. RSB34
    277
    198
    Feb 9, 2013
    ny.
    I’ll be putting it on in the am. Hopefully this stops the derate
    Thanks
  5. RSB34
    277
    198
    Feb 9, 2013
    ny.
    Is there a way to clear the code without a computer? I un hooked the battery cables for about a hr. It's still there. Or will it just become inactive and run ok if that was the problem? I've changed it but have not run it yet.
